04-08-2019, 07:35 PM | #15 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
And of course TC plays no role in corner entries. I too dont like to see vids like these. But they provide a good reminder about maintaining proper balance as key priority. Especially on undulating tracks. Turning and then braking (or even lifting) downhill in a fast corner always ends the same way. And even Stabilitrak wont perform full on miracles if speeds and loads are sufficiently high as it relies on traction of tires to intervene. But it should (could?) provide a bit of a grace regarding necessary correction time. Just my 2 cents. Cheers! |
04-09-2019, 06:48 AM | #16 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Actually, I thought I saw the TC light come on before hearing the engine sound change at least a couple of times. Not sure what that might mean. Norm
'19 WRX 6M (the family sedan . . . seriously) |
04-09-2019, 07:54 AM | #17 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I respect the opinion that I shouldn't be leaning on TC and I do run assists off at AutoX. However I'm not looking to take that chance at tracks like RA. I would rather see in the after session video where I might be leaning too heavily on the PTM. It does me no good to wad the car up with assists off when I could have had PTM on and note in the PDR video where I potentially too reliant on it. Bottom line I think I'm a moderately quick driver but I'm still multiple seconds off the real hot shoes that are in these cars. I'm fine running 1:39ish on OEM tires and having fun instead of coming home without a car. I'm not a TT driver I'm just having fun at track days.
MJK3888 Instagram Link
04-09-2019, 11:50 AM | #18 | |
PTM Race TC allows most slip and if one overdrives it the car may still require mild driver corrections. Just nearly not as active as with it off. PTM Sport 2 allows for less TC slip and that's why GM recommends it (over Race) when tires might be getting too hot. Regardless, most spins are NOT because of TC somehow creating a false sense of security, as TC is absent in corner phases where most spins occur. If one overdrives corner entry, starts a turn and then lifts (or worse: brakes) vs applying throttle to balance a car while it is doing most of its directional change and the rear is very light - results will always be the same. Especially when the track heads downhill which multiplies weight transfer effect. Good for you MJK for stating up front why you thought the spin occured. Most folks will blame everything else Have i ever spun out? Of course! Was it always a driver error? Of course! (Apart from oil on track what the hell else would it be???). The key is to learn from what happened and not to repeated it again. That's how we become better drivers. Not that i would ever suggest spinning a car just to learn! Most importantly: let's have bags of fun out there and use nannies (or not) however we feel fit for us as individuals. That's exactly why they exist. Cheers! |
04-09-2019, 12:20 PM | #19 | |
Drives: A few Join Date: Oct 2017
As for PTM Race, I use it too. Might as well. Like the OP this isn't a TT car for me.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
04-09-2019, 12:47 PM | #20 |
Well my Weekly Speed Secrets from Ross Bentley just arrived in my inbox and guess what? A very interesting blurb from Ross re my point above speaking of balancing the car. Here it goes, just a quick cut and paste specific to this issue. Ref 2nd par below:
Speed Secrets Glossary “In a spin, both feet in”: If you spin, your main objective should then be to limit the distance your car travels (reducing the chance of hitting something), and keep the engine running. As you spin, it’s possible for the car to be moving backwards (as if reversing), but with the engine still trying to turn the driving wheels forward. Combined with heavy braking to slow and/or stop the car, it’s possible to stall the engine. Given all of this, if you begin to spin, your left foot should immediately depress the clutch (left foot “in”), while your right foot applies the brakes hard (right foot “in”). Therefore, in a spin, both feet in. “If in doubt, throttle out”: Every time I hear this piece of advice I want to say, “But, but, but…” The advice suggests that if you’re not sure whether you can make a corner, lift off the throttle. That works sometimes, but sometimes it makes the problem worse. If you wanted advice on what to do with the throttle after making a mistake, I would not tell you “throttle out.” I’d have to say, ‘It depends….” “If in doubt, flat out”: This quote or saying has been attributed the great rally legend, Colin McRae, and should never be confused with the “if in doubt, throttle out” advice just defined above. McRae was famous for being a very aggressive driver, and his driving style seemed to be based on “If you don’t know where the road goes or whether you’re going to make a corner, go to full throttle.” It worked for McRae – until it didn’t, on occasion. |
04-09-2019, 01:19 PM | #21 | |
Drives: Race Car Join Date: Sep 2009
04-09-2019, 01:26 PM | #22 | |
04-11-2019, 06:55 PM | #23 |
Drives: 2018 1SS 1LE Join Date: Apr 2018
Coming from an off road background - 'when in doubt, throttle out' means to smash the throttle until you're out of the hole / obstacle
2018 1SS 1LE (sold) |
04-11-2019, 07:47 PM | #24 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
Sorry, late to party. I’d echo the comments by Trackclub and MJK. As we all know, the SS 1LE is SUPREMELY stable yet neutral. As MKJ found, when you push the envelope she moves around a bit, yes- throttle application when you felt that rear yaw would have likely saved the spin, but a great learning experience if you ask me. Your lap looks really solid, I’d consider using 3rd not 2nd at the chicane before the bridge...less shifting usually faster, especially when you have 450+ lbft with a min speed around 54-55mph. Side note, I’m racing a S2000 at Road Atlanta with WRL in July, can’t wait!
04-12-2019, 09:02 AM | #25 | |
Drives: '18 Black SS 1LE; '01 Corvette Z06 Join Date: Nov 2018
04-12-2019, 09:21 AM | #26 |
Ummm, nope. From actual testing, TC in my car is utterly worthless unless it's that skimpy 325 ft*lbs max torque number that you're talking about. Even so, I turn the electronic one off just about every time I drive anyway.
Norm
04-12-2019, 10:43 AM | #27 | |
"M1SS1LE"
Road Atlanta is a blast! I would love to see what time your 1LE would run around there. I've seen some really fast guys with different wheel tire setups run sub 1:35 there. Both still on 200+TW tires. I was only able to manage 1:38.9 with brand new SC3s up front and slightly more worn rears. The event where this slide occured I only managed 1:40.0 tires were obviously older and it was about 100f ambient all weekend.
04-12-2019, 04:18 PM | #28 | |
Always had to turn it off but the car felt well balanced and easy to drive anyway. |
Thread Tools | |
