04-17-2019, 10:27 PM | #43 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Looks like you may be in luck. I had my car tuned by Vince, the owner of Trifecta here in WA state. He did an absolutely incredible job on my tune. We spent a lot of time together dialing in my tune on their dyno exactly how I wanted it. I highly recommend checking this shop out that's local to you.
http://www.trifectatuningottawa.com You are also local to Turbo Parts Canada. They support our cars as well. Not sure about tuning though. https://www.turbopartscanada.ca
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
04-18-2019, 08:03 AM | #44 | |
Drives: Krypton green 17 Camaro ls 2.0t Join Date: Mar 2018
04-18-2019, 08:29 AM | #45 | |
WOW that would be great, I see on the website they have locations around ottawa and even montreal, but I can't find any address yet. With trifecta I only need the ezflash cable and a laptop right. If yes , I Guess I could just get your guy in WA to send me your tune. Turbopartscanada is good place to know but they only sell turbos. Last edited by Mr.meangreen; 04-18-2019 at 09:20 AM. |
04-18-2019, 10:45 AM | #46 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
04-18-2019, 11:08 AM | #47 | |
I already have a good laptop with hptuners software installed, a usb/obd2 cable cant do the job ? I Have to use the mpvi2 ? |
04-18-2019, 11:14 AM | #48 | |
They never have their address on their website for some reason. They obviously tell you where their location is after you make contact with them. Not sure what mods you have? My tune was specific to my mods. The biggest difference being the JacFab/BNR Recirculation Valve (boost a lator). I don't think it would hurt to try it out though. My tune is also toned down a little for tracking the car. My biggest concern was reliablity and not blowing up the stock pistons and rods over extended periods of "abuse". If it was just for the street, I'd turn it all the up Lol. Turbo Parts Canada makes a sweet ass turbo upgrade for our cars. I would stop by there and check out their shop just for fun.
04-18-2019, 12:06 PM | #49 | |
Okay.. so if I understand good , going with trifecta locks your ecu and only them can play with the tune after, but with the elite package I can always do modification to the tune with them after. It may be a stupid question , but would the ez flash cable work with hptuners on my laptop ? i'm trying to find the cheaper way to go, I was looking at cables on amazon but it looks like its for specific vehicule. is that not just a cable with one usb end and a obd2 at the other end ? |
04-18-2019, 12:34 PM | #50 |
603 Camaros
Has to be there cable. Won't work with any old cable setup.
04-18-2019, 12:45 PM | #51 |
They don't lock your tune. They don't lock your ECU. You can revert back to stock whenever you want.
Yes, with the elite package you can re-tune again whenever you get new mods. I don't know if their EZFlash cable will work with HP Tuners. I highly doubt it. You need to figure out if you are going to run e85? If so, remote tune with Vermont. Not running e85. Dyno tune with your local Trifecta shop. I'm pretty sure every Trifecta shop experience is different. I happen to have an amazing tuner and shop close to me. Get in touch with them, ask questions, go by and check out their shop, ask more questions and go with you're gut feeling. I personally wouldn't by the HP Tuner suite. It's expensive and you really need to know what your doing. I'd save the money for the actual tune and leave it to the experts.
04-18-2019, 12:56 PM | #52 |
04-18-2019, 01:11 PM | #53 | |
if I ever wait to tune it and run it with boost o lator, mishimoto induction pipe, catless dp, drop in k&n is it gonna damage my car or I just won't get max of the mods performance and cel (which I can probably disable with a high end scan tool ) |
04-18-2019, 02:40 PM | #54 | |
04-18-2019, 06:13 PM | #55 | |
05-02-2019, 07:03 PM | #56 |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
Finally installed mine. Prior to installation, I was maxing out around 20.4 psi boost. After installation I read 22.8 psi during a short test. Feels quite a bit peppier at lower RPMs.
Why the hell doesn’t it come from the factory like this?! What a mod. |
