Old 07-10-2024, 05:12 PM   #1
Camaro_Fuzion
Camaro_Fuzion's Avatar
Drives: 2022 Chevy Camaro 2SS Redline
Outdoor/Indoor Car Cover options for 6th Gen 2022 Chevy Camaro 2SS
I have a 2022 Chevy Camaro 2SS with front factory ground effects. What are some good options for a single car cover for both indoors and outdoors that can cover the entire car? I want a cover that will protect my car from tree branches and bird poop. The cover should have multi-layer protection while being easy to strap onto the vehicle.
Front factory ground effects on 6th Gen Camaro
For the win!
Camaro_Fuzion is offline   Reply With Quote
Old 07-10-2024, 05:58 PM   #2
Big Lou 1le
Big Lou 1le's Avatar
Drives: 2023 1le
I have the GM Indoor car cover. I have a 1le and it covers easily the front splitter.
Big Lou 1le is offline   Reply With Quote
Old 07-10-2024, 08:05 PM   #3
Germansheperd1
Germansheperd1's Avatar
Drives: 2024 LT1
Germansheperd1 is offline   Reply With Quote
Old 07-10-2024, 08:38 PM   #4
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
I have an indoor cover from California Car Covers. Very happy with it.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 07-11-2024, 02:49 PM   #5
PostalLDMC
PostalLDMC's Avatar
Drives: 2022 2LT RS Convertible
I used Carcovers.com and found a great one for my RS
PostalLDMC is offline   Reply With Quote
Old 07-11-2024, 03:12 PM   #6
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I only use mine for long term storage learned that lesson the hard way.
dpevans is offline   Reply With Quote
Old 07-11-2024, 06:16 PM   #7
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I use the GM cover for indoors just to keep the dust off. I don't ever recommend using a cover outdoors. No matter how tight the fit and straps, wind will move some portion of it and it will have a buffing effect against whatever it rubs against, and dust/debris will get blown inside of the cover eventually, then it'll be like sandpaper. The longer it stays covered, the worse it will be. Just better off facing the elements in the open and hand washing the car as needed.
Spot detail the bird shit and order a reaper drone to fly CAS against hostiles in the AO. Ideally, one would just mount a C-RAM to the roof, but I think the reaper would be more fun.
https://youtu.be/7D6yPMNxMX0?si=crs1q-htFFK3lwky
2019 1SS1LE M6 Shadow Grey Metallic
4/2/2024 "Under the Knife..." Build in progress
Previous Rides:
1996 Ford Thunderbird V8 - PI Swapped & Comp Cammed 310whp/330wtq (SOLD 2003)
1991 Ford Thunderbird SC - Ported & Tuned (CEF 2005, SOLD 2005)
2001 Mustang V6 (SOLD 2006)
2008 Mustang GT M5 - Procharger D1SC 440whp/480wtq @8psi (SOLD 2013)
2013 WRX M5 - Cobb Tuned (SOLD 2017)
2014 Focus ST - Cobb Tuned & Re-piped Hot Side (SOLD 2019)
GreyGhost702 is offline   Reply With Quote
Old 07-13-2024, 06:57 PM   #8
Camaro_Fuzion
Does you're car cover clip at the bottom on the front and back? Is the cover for in-doors only? It look thinker than some in-door ones I've seen.
For the win!
Old 07-13-2024, 06:58 PM   #9
Camaro_Fuzion
What happened?
For the win!
