Old 07-10-2024, 01:10 PM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
For those of us tuned to run on E85.. ..Are we 'Carbon Nuetral'?
I have been wondering this, especially with the performance aspect considered. Are we more environmentally friendly than we would be if we ran straight premium, even if we make more horsepower?
Need4Camaro is offline   Reply With Quote
Old 07-10-2024, 01:28 PM   #2
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
IMO, no. Fertilizer for the corn and the energy and water needed to make the ethanol isnt green or carbon neutral. IMO, it doesnt matter though. I dont care.
GreenZLE is online now   Reply With Quote
Old 07-10-2024, 01:32 PM   #3
OBD3
Drives: 2023 Chevrolet Camaro 2LT RS trim
From a very narrow point of view the answer is technically yes, but Orgs like Greenpeace, Sierra Club would never think it was enviromentally friendly as they do not want you in a car in the first place no matter how good it is, and that includes Electric because we all know how great they are for the planet.
OBD3 is offline   Reply With Quote
Old 07-10-2024, 02:09 PM   #4
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
This is the right answer. It has actually been proven that adding ethanol to fuel is actually worse for the environment when taking in all of the factors greenzle mentioned. The YouTube channel engineering explained has a great video detailing out how it actually turned out to be worse for the environment.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 07-10-2024, 02:29 PM   #5
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Are we better than gasoline when looking at only tailpipe emissions? yes, for sure.
Are we more carbon neutral that gasoline if you could all of the pieces needed to make ethanol? Nope, not at all. Technically it's the same or worse gallon for gallon. But it might be overall less if you could total emissions/carbon for E85 vs E10.
GM Gen V Calibrator
Old 07-10-2024, 03:48 PM   #6
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I'm not sure that's even true. The higher the Ethanol content, the more you need to achieve the same combustion energy as gasoline.
Diesel would actually have the higher "green" potential, the more you can compress a fuel/air mixture, the more work gets done, and the more complete burn you get. Diesel is still dirtier than gasoline when burned, gram for gram. But when your fleet average goes from 18mpg to 48mpg, you consume a shit ton less petroleum.
Todays turbo diesels, once relieved of their emissions equipment, get phenomenal MPG and power per cubic inch. You need far fewer cubes to get the job done. Of course when you factor in emissions equipment, the fact that emissions equipment destroys engines, DEF fluid, ect., it's a non-starter. Hilariously, they've finally accepted that DEF fluid is actually toxic, and polluting to the environment.
Don't run corn to be green, run it because it's cheap race gas!
2019 1SS1LE M6 Shadow Grey Metallic
4/2/2024 "Under the Knife..." Build in progress
Previous Rides:
1996 Ford Thunderbird V8 - PI Swapped & Comp Cammed 310whp/330wtq (SOLD 2003)
1991 Ford Thunderbird SC - Ported & Tuned (CEF 2005, SOLD 2005)
2001 Mustang V6 (SOLD 2006)
2008 Mustang GT M5 - Procharger D1SC 440whp/480wtq @8psi (SOLD 2013)
2013 WRX M5 - Cobb Tuned (SOLD 2017)
2014 Focus ST - Cobb Tuned & Re-piped Hot Side (SOLD 2019)
GreyGhost702 is offline   Reply With Quote
Old 07-10-2024, 04:01 PM   #7
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
I'm considering more than just tailpipe emissions. Think about the process of extracting, transporting and processing fossil fuels as well. And same goes for Ethanol. There is farming, and chemicals, harvest and processing etc.
GM Gen V Calibrator
Old 07-10-2024, 04:17 PM   #8
GreyGhost702
All of which is still cleaner than making e vehicles and charging them. Hardly anything goes to waste in the refining process to create gasoline. You actually get more gallons of gasoline than base crude was put in at a modern refinery. But in regard to Ethanol, it could be more efficiently made, but we live in a world where material efficiency is tied to money, so if it costs more then it isn't efficient. But I know what you mean.
Previous Rides:
Old 07-10-2024, 09:41 PM   #9
Martinjlm
Retired from GM
Martinjlm's Avatar
Yes
Old 07-11-2024, 08:59 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Cleaner out the tail pipe and that is about it. It's not economical at all and only a small percentage of vehicles will benefit from running it. It's basically cheap race fuel.
Now if you blend the percentage way down it makes more sense. The E15 88 octane is good stuff. I can pretty much run the same timing on that as E10 91-93 octane and it costs a nickel a gallon less than E10 87. And there is very little fuel mileage loss.
On my 3.6 LGX XT6, it will only run 20-22 degrees timing on 87. On the E15 88 it will run all the way up to 26 degrees no problem. Which is max timing the stock tune commands.
So imo Ethanol works better overall(mileage and performance) for most vehicles when blended with pump gas in lower percentages. It doesn't take much to increase knock resistance and you get a lot better fuel mileage.
I know this part is off topic but I figured I would share for those wondering.
2016 NFG 1SS A8
Options-2SS Leather/NPP
