Old 07-09-2024, 11:42 AM   #1
6ixPoint2ss
6ixPoint2ss's Avatar
Drives: from a 2SS to a zl1 1le
Releasing Emergency Brake without starting the engine?
Need to tow my car soon and I cannot start it. I have power, Its a 6 speed manual, how do I disengage the E brake without starting?
6ixPoint2ss is offline   Reply With Quote
Old 07-09-2024, 11:52 AM   #2
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Hold down the power button without the brake for like 5 seconds, it will go through the start up sequence on the dash but wont start. Like an advanced accessory mode.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported throttle body (95mm)
Pray ported intake manifold (stock)
Rotofab CAI
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Cats Removed
Full JLAudio Stereo Build w/ 13-W6
1G1FG1R74G0124089
lDejavul is offline   Reply With Quote
Old 07-09-2024, 11:54 AM   #3
6ixPoint2ss
Wow, that simple? That is awesome, thank you so much for the info.
Old 07-09-2024, 11:54 AM   #4
Rnovrit
Drives: 2018 NFG ZL1-1LE
You can also just get it and push the start button like normal without pressing the clutch. Put your foot on the brake and release the parking brake. I do this all the time when I want to just roll mine a couple feet without starting it.
Rnovrit is offline   Reply With Quote
Old 07-09-2024, 12:27 PM   #5
6ixPoint2ss
I wonder if this will allow me to steer as well. Thanks
Old 07-09-2024, 12:36 PM   #6
Evergreen6
Drives: 2023 Camaro 1SS
You'll want to put it in "Service Mode" which is described in the owner's manual. Someone else mentioned it above...hold down the start button for 5 sec minimum without foot on the brake and it will enter a state much like "on" but the vehicle cannot be started in service mode.
The steering wheel should be unlocked for steering, although you will receive no power assist. Parking brake can be released by applying foot brake and releasing park brake.
Evergreen6 is offline   Reply With Quote
Old 07-09-2024, 12:42 PM   #7
Evergreen6
Here:
Old 07-09-2024, 01:38 PM   #8
Rnovrit
Yes you can steer but without power assist. With mine (6-speed) there is no steering lock. I can rotate the steering wheel at will without assist. The only thing you need power for is to release the parking brake. If the parking brake is already off. You can put the transmission in neutral and push the car around as you like.
Old 07-09-2024, 04:52 PM   #9
6ixPoint2ss
Originally Posted by Evergreen6 View Post
awesome, thanks
Old 07-11-2024, 01:37 PM   #10
6ixPoint2ss
Thank you once again, got my car towed today and your advice worked. Held the start button for a few good seconds, was able to release the e brake and roll out the driveway. Now I wait and pray for good news from the shop.
