Old 07-08-2024, 11:31 PM   #1
1hot.ss
Drives: camaro ss
Procharger heatsoak?
so i have a procharger (p1sc1) and the it seems to heatsoak pretty bad i can only get maybe 2 good pulls before the car feels super sluggish and slow. Anyone else have this issue? what can i do to get around this
1hot.ss is offline   Reply With Quote
Old 07-08-2024, 11:32 PM   #2
1hot.ss
Drives: camaro ss
just for context i don’t run meth and im on 93 my only mods are headers and the blower on 6psi
Old 07-09-2024, 07:43 AM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Prochargers are air to air intercooled and their entry level intercoolers aren’t great, so being in Florida compounds the issue. You can upgrade the intercooler or add meth…probably the two best options.
Old 07-09-2024, 09:00 AM   #4
1hot.ss
Drives: camaro ss
I have their stage 2 intercooler. Is there another intercooler that you reccomend?
Old 07-09-2024, 10:28 AM   #5
Joshinator99
If you’re only at 6 psi and their “Stage 2” intercooler still isn’t cutting it, then you might as well just add the meth kit.
All that said, is there a reason why you’re not running E? That would really minimize the effects of higher IATs.
Old 07-09-2024, 10:35 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Air to air Intercoolers are good at removing heat after a pull but they are not great at controlling heat during a pull. I have personally witnessed a P1x car with stage 2 IC pushing 9psi peak hit 156 degree temps by the bottom of 5th gear (A8) car. So I could easily see a P1sc kit even on 6-7 psi in the Florida heat hitting those temps. And with the stock LT1 you have to be very aggressive on timing retard in regard to air temp when running pump gas. I could only get 11 degrees of timing out of that P1x car in the heat without KR. When it was cold it would run 15 degrees.
As Josh mentioned, you either need to run a blend of Ethanol which will allow more timing with higher temps. Or get a Alky kit for cooling and octane.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 07-09-2024, 11:07 AM   #7
Joshinator99
Great info as always King.
Old 07-09-2024, 02:49 PM   #8
1hot.ss
Drives: camaro ss
the reason i haven’t run E is because i still have the stock bottom end. didn’t want the car to make too much power ��
Old 07-09-2024, 02:57 PM   #9
1hot.ss
Drives: camaro ss
i also have a buddy with a 900whp camaro on the d1x blower same intercooler and he seems to have the same issue as me even though he does have meth and E
Old 07-09-2024, 03:27 PM   #10
Joshinator99
Wrong answer lol… E makes the stock bottom end live much LONGER than plain 93. The difference in detonation resistance is huge.
Old 07-10-2024, 02:21 PM   #11
1hot.ss
Drives: camaro ss
so even tho the car will make a good amount of more power on E it’s safer?
Old 07-10-2024, 02:23 PM   #12
KingLT1
KingLT1's Avatar
Yes
2016 NFG 1SS A8
Old 07-10-2024, 04:01 PM   #13
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Provided you have the pump and injectors to flow the addition of Ethanol, absolutely. Wouldn't do you much good if you add E and then run out of fuel at the peak boost
2019 1SS1LE M6 Shadow Grey Metallic
4/2/2024 "Under the Knife..." Build in progress
Previous Rides:
1996 Ford Thunderbird V8 - PI Swapped & Comp Cammed 310whp/330wtq (SOLD 2003)
1991 Ford Thunderbird SC - Ported & Tuned (CEF 2005, SOLD 2005)
2001 Mustang V6 (SOLD 2006)
2008 Mustang GT M5 - Procharger D1SC 440whp/480wtq @8psi (SOLD 2013)
2013 WRX M5 - Cobb Tuned (SOLD 2017)
2014 Focus ST - Cobb Tuned & Re-piped Hot Side (SOLD 2019)
GreyGhost702 is offline   Reply With Quote
Old 07-10-2024, 05:05 PM   #14
Joshinator99
Yes
This is the way.
Also true lol!
