Old 07-06-2024, 08:11 PM   #1
balneet2
Drives: 2020 camaro ss
Smile Build help for ~ 600 wheel hp
Hey guys, this is my first post I have been looking through for probably a year now and I want to look at my options for getting around 580- 600 - about 650 whp. I have a 2020 camaro ss with the A10, looking at a budget of around 5k but able to play around with it. It would be nice with a build list. Thank you guys! Also if I need a torque converter. I don't mind going FI or N/A. I'm already fbo with e85 running 450 whp. Edit. I'm doing all the labor myself so with that in mind. Also I can play with it up to $6-7k. My parts already installed are - 1 7/8th lth - flex fuel kit - 95 mm lt5 throttle body - lt2 intake manifold - cold air intake - no cats - x pipe. Basically all the "bolt-ons".
balneet2 is offline   Reply With Quote
Old 07-06-2024, 10:00 PM   #2
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
I don't think that is possible for only $5000. I think maybe you could get close to 500whp. I'm sure others might know a way to get some more power for the money.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 07-06-2024, 10:36 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Do like Laynlo15 did and find a used Maggie2300 or Whipple 2.9 kit, that would definitely do the trick. Don’t need a Maggie 2650 or Whipple 3.0 to hit that power number.
Old 07-07-2024, 12:06 AM   #4
balneet2
Even if I'm already fbo? I'm at 460 whp.
Thank you!
Old 07-07-2024, 12:13 AM   #5
Hostile_1LE
[QUOTE=balneet2;11434249]Even if I'm already fbo? I'm at 460 whp.
Thank you![/QUOT
I was assuming going from 0 mods to your goal.
I think with a strong FBO/Heads/Cam setup, ~580whp is possible, granted all dynos will show different power. With a big cam and an increase in compression, It could be done. But you could expect to pay close to $5000 in parts, and even more for labor.
I spent about $4500 on parts for my heads cam setup, but I am nowhere close to 600 whp.
Old 07-07-2024, 02:10 AM   #6
s346k
s346k's Avatar
Drives: like an old lady
i believe the port injection conversion and blower he ran was easily $5k. injectors alone are prob $1k.
Old 07-07-2024, 08:32 AM   #7
Joshinator99
You could run that used blower kit on say 7 psi and just keep your stock fueling. 550-570 WHP all day long.
Old 07-07-2024, 10:05 AM   #8
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
Parts and labor on a NA build with everything most places are around the 10k mark. One place charges 20k for a Cam Head package. That is changing pistons and all that comes with that, heads with exchange, cam, LTH, Fuel Management delete, including dyno before and after, Everything needed for a complete upgrade, Drive in drive out. The 10 grand is about the going price in the Houston area,,, give or take
KC64 is online now   Reply With Quote
Old 07-07-2024, 10:37 AM   #9
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Here in south Florida, prices are much higher! My upcoming install consists of the following:
Kook's LTH's (ceramic coated)
Rotofab cai
NGK plugs
E85
before and after Dyno
Tune
Quotes ranged from $4k to $6K
SSShark is offline   Reply With Quote
Old 07-07-2024, 11:34 AM   #10
KC64
Gray Ghost
KC64's Avatar
Rotofab cai
NGK plugs
E85
Tune
H
4 to 6 grand sounds about right, the CAI is a big chunk of that, plus the LTH those two are not cheap. It gets expensive very quick.
Old 07-07-2024, 11:43 AM   #11
SSShark
SSShark's Avatar
It sure does. I had no idea going in, how quickly things would add up.
Old 07-07-2024, 11:55 AM   #12
s346k
s346k's Avatar
i saw those as 2 different statements.
i believe a factory LT4 would easily meet the goals, as well. idk which way to go with a blower, stock or aftermarket. i was never interested in going fast.
it helps to know if the op is providing the labor for parts install. labor is a big chunk of cost.
Old 07-07-2024, 07:03 PM   #13
KC64
Gray Ghost
KC64's Avatar
You may want to look at a ProCharger, you can do the stage 2 without changing anything on your car, it is all bolt on, tune it and go. Out of the Superchargers it is the most simple and least expensive without having to change anything. Just a thought. Good luck and all the best.
Old 07-08-2024, 12:04 PM   #14
bessen13
Drives: 2020 Chevrolet Camaro SS 1le
I have a 20 M6 1le and just did a motor build as well as HCI. I obviously spent more than you're looking to spend but I have a very good idea on what it would take to get to 6oo ish whp. My setup is Gpi LT NFC cam, ported and milled heads (.040), 1 7/8 LT headers, e85, stock lt2 manifold and the LT5 throttle body. Like you plan to do I did all the work myself, if you are already fbo you can easily make 580-600 whp for under 5k.
bessen13 is offline   Reply With Quote
build, help me, list, n/a, price
