Old 06-15-2018, 11:19 PM   #15
dchesrown
Drives: ZL1-1LE
I have fast lap at Mid-Ohio for Zl1's. Stock pads they are more than ok. BTW I had a pm flebay=eBay.
dchesrown is offline   Reply With Quote
Old 06-15-2018, 11:24 PM   #16
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Originally Posted by DANACO View Post
Does anyone know the difference between the 1Le and ZL1 pads, are they not the same calipers on each car ?
ZL1 & ZL1 1LE cars have exactly the same calipers and brake pads from the factory
Old 06-16-2018, 02:52 AM   #17
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Originally Posted by Provoste View Post
GM Parts direct. $220 for front pads, $80 for rear. Seriously.
That's amazing! I remember when I saw the price for the Brembo pads on my Evo, i was like That's pretty reasonable though
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 06-16-2018, 08:15 AM   #18
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by Stephen12ZL1 View Post
My definition of OK wasn't clear. Maybe the inclusion of the word "just" turned the tone to "meh, OK". For stockers they are acceptable considering the performance of the ZL1. No doubt DTC 70/60 eat rotors like potato chips, and I can believe the seals could deteriorate quickly using these. I prefer the brake torque of the G-LOC pads as they are more confidence inspiring at 160mph compared to stockers. My calipers have thus far been flawless with 2K track miles at VIR. Personal preference prevails in this discussion.
Originally Posted by seanblurr View Post
I would say the stock pads are far beyond just ok. They have provided nearly everything I've asked and will probably double the life of the rotors compared to any real race pad. This is not to say that I won't finally start using a race pad again, but at this time I see no reason.
I've used G-Loc and currently have a set of Hawk DTC70/60's. Sure, initial bite is much better but race pads destroyed my calipers. Caliper temps were nearly 200 degrees hotter with race pads. Melted all the piston seals and discolored the calipers. Stock pads don't get nearly that hot, so my calipers are holding strong.
I'm going to try to keep the stock pads in as long as I can, but I have no hesitation going back to race pads if need be. If I can say this humbly, I'm no slouch behind the wheel either. So these pads can't be that bad...
I consider you both right. Have used both the stock pads, which are very, very (did I say very? ) good....and the G-Loc pads from JP (at Stephen's recommendation) which I do believe have more bite and last longer. Ran both at RoadAmerica, Road Atlanta and recently ran just the G-Locs at Autobahn CC.
The G-Locs didn't appear to be harder on the rotors and calipers.....until Autobahn CC that is. It is a more technical track with lots of corners and you're on the brakes more often with fewer long straights to cool them off. Ended up with some heat checked rotors and the calipers got so hot the "1" on the rotors emblem is now a golden yellow vs. White. Wow they got hot..... The G-Locs can be harder on the rotors/calipers, perhaps impacted by track configuration.
My next event is three days at RoadAmerica so I'll be reloading with a fresh set of the G-Locs (for the end of those 150-160 mph long straights!) but when I go back to ABCC in August I'll probably use some OEM pads.
I think both personal preference and track configuration prevails. Both very good choices. These ZL1's have some great brakes!
Just my $0.02.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 06-16-2018, 08:39 AM   #19
Stephen12ZL1
Drives: '21 ZLE A10
be careful swapping to OEM pads or vice versa once the brake pad material has been embedded into the rotor. Stick with like pads after tracking unless you are swapping to new rotors. I suppose a quick clean up with a scotchbrite and rotary device would help also. Chattering and inconsistent modulation can occur.
Old 06-16-2018, 09:18 AM   #20
2010REDSS
2010REDSS's Avatar
Agreed. Good reminder. I typically have good luck cleaning them up with 0000 steel wool.
Old 06-16-2018, 11:16 AM   #21
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
This is especially important for G-Loc/Carbotechs compound. They can be an entirely different pad based on their initial bedding.
seanblurr is offline   Reply With Quote
Old 06-16-2018, 11:53 AM   #22
Badmojo
aka BeastZL1
Badmojo's Avatar
Thanks for this tip. I've built up a pretty good layer of stock pad material on my front rotors. You can tell a difference significantly after you get the transfer layer.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 09-18-2018, 08:46 PM   #23
Apexslayer
Drives: Zl1 1le
Stock pads are outstanding! Are we sure that the ones on GM Direct are the same that it came with as OEM. I know the part nos are the same, but I can't believe the pricing.
Apexslayer is offline   Reply With Quote
Old 11-25-2018, 04:43 PM   #24
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Does stoptech make z23 pads for ZL1?
cmeJATT is offline   Reply With Quote
Old 03-27-2019, 02:48 PM   #25
Mcardenal
Mcardenal's Avatar
Drives: 2018 Nightfall Gray Metalic ZL1 A10
Originally Posted by dchesrown View Post
Fleabay. I have already received my first set new in the box. Ordered 2 more fronts one rear. Item # 162475914479 fronts. Tell him you want my same deal make offer 100 fronts 50 rear. ( Separate item # same seller rears)
Found this thread and your post. Thanks for the tip and the item numbers. Waiting on a response to the offer.
Mcardenal is offline   Reply With Quote
Old 03-30-2019, 03:04 PM   #26
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Just bought both sets for $150. Thanks for the tip
Heartbreaker is offline   Reply With Quote
Old 03-30-2019, 06:50 PM   #27
PROMETHEUS
PROMETHEUS's Avatar
Just bought a set of fronts from ebay dealer, $100. Thanks for the info. I am hoping it wasn't to good to be true!
Old 03-30-2019, 09:39 PM   #28
PROMETHEUS
PROMETHEUS's Avatar
Just bought the rears from same ebayer, $50 Item #152512007907
