08-12-2020, 10:23 AM | #1 |
Drives: 2SS Join Date: Mar 2018
Is it time for a new starter?
As u can see in the vid, the car needs like 4ever to start. Same battery tested on other SS, starts right away....... so.....what do you think guys? https://streamable.com/b1ik4c
08-12-2020, 10:44 AM | #2 |
This is a common issue and there seems to be no clear solution. I had it about 1.5 years ago while still in warranty and the dealer solution was a new battery. Now the issue is back. Many have tried new batteries, starters (or both), wrapping the starter with insulation and even an additional ground wire (engine to frame). The results of all of this are inconclusive.
My issue is always on the restart of a fully warmed up engine that has set only a few minutes. Of late I have popped the hood between starts to get some heat out of the engine compartment. That seems to help. I also do not kill the engine while waiting in line at the bank or whatever. That wastes fuel but I don't risk facing a no start. I'm convinced this is heat soak to the starter. Now that I am out of warranty I'm going to look for a better aftermarket starter and battery the next time I have a failed start. Good luck - it is very frustrating!
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 08-13-2020 at 08:20 AM. Reason: spelling |
08-12-2020, 10:52 AM | #3 | |
08-12-2020, 09:28 PM | #4 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
Headers or any mods ?
08-16-2020, 01:08 AM | #5 |
Yh, primary cats delete, and heat shield from starter also seem to be gone 😅 Idk what was previous owner thinking but car was trashed in many ways.........this's what u get when u buy salvage car from auctions, small body damage in picture but disaster under the hood......not to mention car has only 9k miles on the clock, it should have been like new......😔
09-07-2020, 02:03 PM | #6 |
Does anyone replaced starter by himself? I read in the workshop manual they just say, unscrew bolts, cable nut and then remove starter. There is no way in hell u can remove it, I tried every possible way and angle, it won't come off due to the exhaust manifold being in the way. Why would they write an incomplete procedure in the book?
09-07-2020, 11:11 PM | #7 | |
09-09-2020, 02:06 PM | #8 | |
REPAIR INSTRUCTIONS > STARTER REPLACEMENT (LT1) > REMOVAL PROCEDURE Raise and support the vehicle. Lifting and Jacking the Vehicle (Base)Lifting and Jacking the Vehicle (HP) . 1. 2. Remove Starter Shield Replacement (LT1) Fig 1: Starter Solenoid Cable Nut Courtesy of GENERAL MOTORS COMPANY Remove Starter 3. Solenoid Cable Nut (2) 4. Remove Battery Positive Cable (3) 5. Remove Electrical Connector (1) Fig 2: Starter Bolts Courtesy of GENERAL MOTORS COMPANY Remove 6. the starter bolts (1) 7. Remove the starter (2) REPAIR INSTRUCTIONS > STARTER REPLACEMENT (LT1) > INSTALLATION PROCEDURE Fig 1: Starter Mounting Bolts Courtesy of GENERAL MOTORS COMPANY CAUTION: Refer to Fastener Caution . 1. Install the starter (2) 2. Install the starter mounting bolts (1). Tighten to 50 N.m (37 lb ft) Fig 2: Electrical Connector Courtesy of GENERAL MOTORS COMPANY Connect 3. the electrical connector (1). 4. Install Battery Positive Cable (3). 5. Tighten Starter Solenoid Cable Nut (2) to 12 N.m (106 lb in). 6. Install Starter Shield Replacement (LT1) 7. Lower the vehicle. Ain't big deal I loosend up the exhaust manifold and it was easy afterwards. One more favour, does anyone know the p/n for exhaust manifold bolts? I can't seem to find them on any GM shop website diagrams, they are incomplete :( |
09-10-2020, 02:19 PM | #9 |
Wanna try something?
Disconnect both battery terminals and touch them together. Then reconnect everything. Let us know if that helped. This just fixed that issue for me, I’m 90% sure the improvement wasn’t just from repositioning the terminals.
09-10-2020, 03:14 PM | #10 |
Here you go, this is an older diagram, but the part numbers do exist and thus likely haven't changed in the meantime. The bolts you're after are either #24 or #26 below.
09-12-2020, 08:13 PM | #11 |
Drives: 2018 Camaro RS 3.6 A8 Join Date: Jun 2018
There are several videos on YouTube that show a standard battery change, other than the awkward location.
