09-01-2020, 09:38 AM | #1 |
Drives: G8 GXP Join Date: Nov 2019
WTB: Z/28 Stock Brake Pads - Front or Front & Rear
Looking for a set of new or slightly used stock front Z/28 brake pads.
Will consider a set, but only really need the front. Feel free to PM Thanks |
09-01-2020, 11:36 AM | #2 |
Rock auto has new sets. The last time I got mine from summit, they were for corvette, which is the same for front but include the incorrect pad wear sensor harness.
09-01-2020, 01:28 PM | #3 |
Yep. Just seeing who has a set kicking before I bite. I am not working on a Z/28 application so i don't need the sensors at all.
09-02-2020, 07:45 AM | #4 |
Drives: 14' Red Z/28 #336 Join Date: Mar 2016
I have some well used ones that I got from a guy that tracked his.
09-02-2020, 08:28 AM | #5 |
Not looking for well used haha. These will be used for the street not just mock up work
Thanks though ! |
09-02-2020, 08:58 AM | #6 |
You might be looking at the incorrect brake set up for an inexpensive new/slightly used brake pads. If you have the ceramic rotors that are actually still good, you might be better off selling those and going with girodiscs or ZLE setup. But I’m want to tell anyone what to do or run. I just doubt anyone has $1k pads that they want to sell, but maybe sharing more about your project might inspire someone to help you out.
09-02-2020, 01:58 PM | #7 | |
Well aware, appreciate the advice, but I am not going to standard rotors. Just having some fun with a project and have been wanting to do the CCMs on a car way back when I worked on the ZR1. I have found some for $400, i only need the front really. |
02-25-2021, 10:30 AM | #8 |
Bump
Looking to get back to this |
02-25-2021, 07:57 PM | #9 |
Have a look on the Corvette Forum you might be able to find a set there.
Orange Krush II
03-02-2021, 03:46 PM | #10 |
Yeah I try to avoid the parts onslaught on so many forums. Easier to keep track with less haha
03-23-2021, 03:56 PM | #11 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
I have some stock brembro pads with 300 miles on them? That work for you? Were on my 2011 SS
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
