07-25-2015, 02:41 PM | #1 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Front bumper cover
Can someone tell me what the part number is for a front bumper? Also, how much should it be to paint one... I scrapped up the bottom of mine... Considering covering it with a 1le splitter or just getting a new cover
07-25-2015, 02:49 PM | #2 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
If it's only scrapped it can be repaired easily.
07-25-2015, 03:11 PM | #3 |
I'll get a pic later. Its like if someone parked over the stopper... Only mine was from catching air
07-25-2015, 03:42 PM | #4 |
Drives: 2014 2LS RRM Join Date: Feb 2015
That can be repaired. Should be about $300 to $400. It will look like new. We have had several bumper covers repaired and they came out perfect. One was torn and they were able to fix it.
07-25-2015, 09:43 PM | #5 |
Okay, better off getting the 1LE splitter then. I do have sad news. So, what caused this was me spinning out into a sandbank and then "bouncing" back onto the track behind the sandbank.. pretty much the equivalent of going over a -although small- curb. So now my steering wheel is slightly off. I checked the rods when changing my wheels and they seemed str8 to a novice's eyes... so im wondering if its the r+p or just the alignment is off some.. to go straight I have to turn my steering wheel like .. 5 degrees right
07-25-2015, 10:01 PM | #6 |
Drives: 2SS/RS Join Date: Sep 2008
I don't have links but a new OEM fascia runs $350-$400 and then you're looking at an extra $200-$300 paint. If cost is an issue, than a splitter will by far be the cheaper option.
07-26-2015, 05:11 AM | #7 | |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
Chances are, it's just the alignment. When you take it in, make sure to tell them to check everything out, just in case something is bent.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
07-26-2015, 09:59 AM | #8 |
I'm bringing it to a Mr.tire place in about 30 mins. More to follow
07-26-2015, 11:28 AM | #9 |
Yup.. Tie rods are fine. Just moved the rack over some. Thanks for the part number
07-30-2015, 08:54 AM | #10 |
Drives: Yellow 2012 Camaro 2SS/RS Join Date: Jun 2015
pics of your bumper? also where are you ordering your 1le splitter from? i too scrapped the bottom of mine thought about getting dr colorchip or getting a 1le splitter to cover it up
