08-09-2022, 01:42 PM | #1 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Rear license plate mounting
Does the rear license plate just screw through the rear body plastic? I see there are several dimples in the plastic that I assume line up with license plates from various countries. If it just screws to the body, have you found a good looking plate surround so it looks a little more finished?
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
08-09-2022, 02:37 PM | #2 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Yes
08-09-2022, 02:53 PM | #3 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
I like screw covers and no frame. Noticed my reflection on the covers.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
08-09-2022, 02:57 PM | #4 |
08-09-2022, 03:09 PM | #5 |
+1 for the silicones. The only one that doesn't scratch the paint, plus it has tiny weep holes at the bottom, so it doesn't retain moisture either. The ones I bought have nice black screw covers as well, which makes for a proper, finished look.
08-09-2022, 04:33 PM | #6 |
Thanks for the ideas, guys!
08-09-2022, 06:06 PM | #7 |
Ya... Thx Guys! I just ordered a silcone one.
08-09-2022, 09:18 PM | #8 |
Drives: 2022 1SS Team Joe and Becky Join Date: Apr 2021
I just put a small rubber washer between the plate and the paint on each screw.
Keep in mind that area will be covered up in the same way the whole time you have the car. |
08-09-2022, 09:27 PM | #9 |
Drives: 22 ZLE M6 Join Date: Jul 2014
+1 on silicone … have used these and I highly recommend them!
Rightcar Solutions Silicone License Plate Frames https://a.co/d/cbRhwqo |
08-10-2022, 09:54 AM | #10 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Another option:
I like my metal chrome "outline" plate frame, but appreciated the protective intent behind the silicone - so I trimmed off the raised portion of a silicone plate frame and mounted that behind my chrome frame. (Might be more cost effective to cut a piece from a sheet of flat silicone for this approach.) |
08-11-2022, 12:01 AM | #11 |
Drives: 2022 2SS Join Date: Mar 2022
I had the rear bumper off of mine to install an areo package; there is extra reinforcement behind each dimple for the license plate screw. Just don't get it off center like some I have seen!
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
08-11-2022, 01:24 AM | #12 |
Drives: Chevrolet Chevy Join Date: May 2022
If you guys want true protection that won't damage the paint: https://www.homedepot.com/p/Everbilt...9565/203661091
Directly onto the paint where the plate will contact. At least 2 behind there. Silicone plates, I highly doubt thats a tight seal which means over time, dust and dirt will get behind it, and vibrations over time may rub all that into your paint. Similar to those black bras you install on the front end, like the old days. Cringe. Same if you stick some kind of pad/washer onto the plate itself. If you stick those bumper pads onto the paint itself, dirt/dust will only rub against the plate, not the paint. Pads will also allow water to drain and the area breathe back there. Yes, I'm this ****ing anal. |
08-11-2022, 11:27 AM | #13 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Thanks. Ordered this for my new "to me" car.
08-11-2022, 01:02 PM | #14 |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
Thread Tools | |
