08-05-2022, 02:40 PM | #15 |
[QUOTE=1LEornothing;11210632]LT1s came out for the 2020 model year and were first built in Q3 2019. I have one of the first LT1s ever produced.
King, I truly hope you are correct about the LT1 having the ZL1 low side pump from the factory. That would be some of the best news I've heard concerning the 6th gen in a long time and would REALLY simplify my fuel system upgrade for the blower. I hope someone who knows for certain can chime in and lay down the facts for us.[/QUOT You can use your vin and call your local dealer and they can tell you the part number on your pump. That's what I did if it is it sure has a different part number then the SS or ZL1. The convertible has another part number so who really knows. I'm about to find out on the dyno in a few weeks.
08-05-2022, 03:13 PM | #16 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
[QUOTE=laynlo15;11210714]
08-05-2022, 03:24 PM | #17 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
My 2019 SS did NOT have the ZL1 pump. I was hoping it did as there was conflicting info online. Called dealer gave them the VIN and they gave me the part#. Was correct when I pulled it. I do not know about 20+ though.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-05-2022, 03:44 PM | #18 |
Could have changed in 2020. Not sure
08-05-2022, 07:13 PM | #19 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
08-05-2022, 07:38 PM | #20 | |
08-05-2022, 09:47 PM | #21 |
Not doing the Lt4 HPFP or the Lt4 injectors. Doing the toohighpsi port injection. Can run off the stock Lt1 fuel system as long as the low side can keep up. Also going to run the JMS V2.
https://toohighpsi.com/?fbclid=IwAR3...YLy__GRh7ayeRs Plus the 10 rib setup https://toohighpsi.com/products/cama...s-lower-pulley
08-05-2022, 10:40 PM | #22 | |
08-06-2022, 05:42 AM | #23 | |
08-06-2022, 06:45 AM | #24 |
Mine made 436/441 and that was on the stock Lt1 fuel system and the low side stayed right at 68 psi. That doesn't mean it has the Lt4 or Lt1 low side. Ted may or may not be correct, but I sure wouldn't bet on it just because it didn't drop on the dyno.
08-06-2022, 07:01 AM | #25 |
Comparison from my C7 and Camaro Lt1 on the logs, no BS
So I pulled logs from my C7 and Camaro and found these results on low side PSI
C7 Corvette-6667 rpms the low side desired was 73 psi, actual was 48 psi on the dyno and logs at the track Mods are- Msd ported IM, Ported 95mm TB, SE long tubes and x pipe, E60 plus High side desired was 2500 and actual was 2661 Lt1 Camaro-6660 rpms the desired low side was 73 psi, actual was 68 psi on the dyno and logs at the track Mods are-Lt2 Ported IM, Stock 95mm TB, Rotofab CAI, E60 plus, everything else is stock. Desired High Pressure was 2611 and actual was 2615 Now these cars both have the same Lt1 High Side but, this tells me that the Camaro probably has the bigger in tank pump since there is 20 psi difference in the Low Side. Makes sense to me and that's what I think Ted meant when he said the low side was not dropping off like it normally would on E.
08-06-2022, 07:56 AM | #26 | |
08-06-2022, 08:43 AM | #27 | |
Drives: 2019 2SS Camaro Join Date: Apr 2012
08-06-2022, 09:16 AM | #28 | |
No idea why this shit turns sideway when it correct in my Photos. Go figure
