06-04-2022, 11:52 AM | #15 | |
Drives: Chevrolet Camaro Join Date: Apr 2022
06-04-2022, 12:30 PM | #16 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
I have R888s and love them. They hook well. Noise isn’t that bad…..IMO.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
06-04-2022, 01:25 PM | #17 |
I run 888 too, and I can't hear the whine when my windows are up. I've run 3R, 4S, NT05, ET Street, and now 888 and these are best on dry surfaces. They all suck in the wet, but 4S is best.
'20 ZL1 1LE A10,
06-04-2022, 02:14 PM | #18 | |
I had difficulties carrying a conversation with my wife in the car when running these Toyos, even cruising, whenever the road surface was anything short of brand new blacktop.
06-04-2022, 05:41 PM | #19 | |
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 06-04-2022 at 07:42 PM. |
06-06-2022, 07:18 AM | #20 |
Added dyno sheet to original post.
06-06-2022, 07:50 AM | #21 |
Good info, thanks. I manually hacked, pardon, "overlaid" my curves onto your dyno sheet just as a rough ballpark reference comparison (yes, I have a tiny torque dip near the top).
Neither the runflats nor the PS4S are likely to hook up from zero, but the PS4S at a slightly lowered pressure will work from a much slower roll. It'd be interesting to find out exactly how low you can go with the starting speed, but of course you'll need those tires and then some guinea pigging willingness
06-06-2022, 08:27 AM | #22 | |
06-06-2022, 09:14 AM | #23 | |
Thanks, I'll be here waiting for the dragy screenshots.
06-08-2022, 09:02 AM | #24 |
Surprisingly the car hooks in 2nd gear... And damn is it fast! Still need to get dragy data as I threw a check engine light on the way home and they're sending me a revised tune.
06-08-2022, 10:23 PM | #25 |
Awesome, great to hear -150 rwhp does have some advantages
06-09-2022, 08:49 AM | #26 |
06-09-2022, 11:47 PM | #27 | |
Yes, my car is an A8 (tuned). What I typically do is blip the throttle to the floor, which engages performance shift mode, the A8 downshifts to the optimal gear for max torque at that speed, rpms climb to 3500-4000, and then I floor it for some bam-bam straight line shift action.
06-10-2022, 05:58 AM | #28 |
What does your actual dyno sheet look like? Because this one being 46 mph to 142 mph, in an M6 car with different gear ratios than your A8 car, and with different tires than yours as well, means that your drawing is very much apples to oranges, in other words, bogus. Would need RPM-based graphs from both in order to pretend-overlay like you did. Yes I am pointing out that even if your dyno operator screwed up like this one, and gave you a speed-based dyno sheet instead of the correct rpm-based, the fact that your gearing does not match his would invalidate a straight comparison of mph vs power.
