11-18-2016, 07:00 PM | #1 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Help putting together a cam and head package on Texas speed.
This will be my first modified more than basic bolt on vehicle and have some questions. I plan to order my cam and heads either tomorrow or Monday and want more info on what I am purchasing and if I am purchasing the correct items. My Goal is to be around 500 hp, and I want a nice sounding Cam when I pull up to stoplights, this has been a long time dream of mine. My number 1 thing that I want is still daily driver reliability. I will probably never race the car other than random spirited driving.
1. What is the +32 fuel lobe for and do I need it. 2. I have chosen not to include an oil pump. I figure I can use the stock oil pump, is this ok? 3. Do I need the trunion kit. 4. Can anyone explain the differences between the various vvt cams? I plan on choosing VVT1 but some more info would really be appreciated. 5. Is it easier to do the Heads while installing the Cam or is it not necessary.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" Last edited by bybcous; 11-18-2016 at 08:23 PM. |
11-18-2016, 09:15 PM | #2 |
Twin Turbo
Drives: 2016 2SS Join Date: Jul 2016
I'll take a shot at answering yours questions but I'm learning still as well.
1. The 32% fuel lobe is designed to increase fuel supply to the injectors. Not Really sure if needed for NA applications 2.You can skip the oil pump if you like but wouldn't hurt to upgrade while your in there. 3. Trunion kit is not necessary but a cheap upgrade to the factory rocker arms. I never had a problem or failure with LS rockers using big lift cams. Not sure if LT rockers are similar. 4. Can't really help with that 5. You don't need to change the cylinder heads while swapping the cam.
Boost, Boost & More Boost
Instagram = BoostedSS |
11-18-2016, 09:22 PM | #3 |
Thanks for answering but after looking at my budget, i think I am going to go cam only. This may sound crazy but again my only goal is to pick up some more power, and to have that cam sound. I will contact Texas speed tommorow to get there advice and place my order. If anyone else wants to chime in i would still appreciate it.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
11-18-2016, 10:36 PM | #4 | |
Drives: 2016 2SS Camaro Join Date: Sep 2016
If you are keeping the active fuel management you don't have to pull the heads. Most after market cams require "DOD Delete" and the heads have to come off because the lifters have to be changed. The VVT!, VVT2, etc is just their own internal code for cams with different specs (lift and duration).
If you go the their camshaft packages for that model car you will see in the drop down menus that you have to select one of the DOD delete packages (differing options). You have to pull the heads because the lifters have to be changed for any of their cams. The rocker arms will usually be fine, but some like the piece of mind of replacing the factory trunions with the Comp version. Quote:
11-20-2016, 09:37 AM | #5 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Are you manual or auto? Because if you are auto and youre nat changing your converter yoyll have to use their sv cam. If youre manusl you csn do do any stg cam. All their cams are dod delete so heads have to come off. If youre planning on upgrading rocker trunnions I would recommend the straub kit insted of the comp
http://www.straubtechnologies.com/ls...ts-with-bolts/
Ported intake manifold and throttle body kooks 2" headers no cats
11-20-2016, 09:56 AM | #6 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
11-20-2016, 01:52 PM | #7 | |
1ss/Auto-Hyper Blue
07-24-2022, 10:31 PM | #8 |
Drives: 2019 ZL1 Join Date: Oct 2020
Thread Tools | |
