11-20-2015, 03:06 PM | #15 |
The J6A P/N: 172-2673/75 is the black Caliper
11-20-2015, 04:33 PM | #16 |
Trust me I'm a Scientist.
can I just buy any steel braided lines for this set up?
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator. |
11-20-2015, 05:20 PM | #17 |
23242510 This is the caliper piston kit P/N: for those that already have 6 piston calipers.
www.iamgmparts.com has them for 106 a set. An I've looked at pics of ZL1 rotors and can they or can they not be disassembled??? If so and the Vette rotors are the same maybe it's possible to swap the rings. Last edited by olblue75; 11-20-2015 at 05:24 PM. Reason: H |
11-20-2015, 05:34 PM | #18 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
No. Escort GT braided lines will not fit.
You must buy the braided lines for a Camaro ZL1 if you are buying all 4 of them for a Camaro. If you are just purchasing front line you can buy ZL1 or gen2 CTS-V.
11-20-2015, 07:37 PM | #19 |
Good to know! do you know the part number?
11-21-2015, 07:45 AM | #20 |
Drives: Black 2011 2SS/RS Join Date: May 2011
11-21-2015, 08:53 AM | #21 |
Thank you! Few put the effort into looking into something for themselves......As you can see from my posts it is a pet peeve of mine
11-21-2015, 11:01 AM | #22 | ||
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
11-21-2015, 11:59 AM | #23 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I'd like to look into whether the 2016 CTS-V Caliper and 15.4" rotor will bolt on. It is too new to dig up part #s unfortunately.
11-21-2015, 03:41 PM | #24 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
The big V Calipers will fit but the rotor has a different offset than the zl1 rotor. By the way all part numbers are released and in service,
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
08-28-2017, 06:03 PM | #25 |
Drives: 2SS 1LE Silver w/Recaro NPP Join Date: Feb 2014
If using z06 calipers, would z06 pads fit?
It seems logical that Z06 pads would be appropriate.
-BtrBimmer
'14 2SS 1LE NPP Recaros |
08-28-2017, 09:23 PM | #26 |
I bought a set of Z06 pads with 30 miles off the corvette forum for 60 bucks they were identical to the ZL1 Brembo pads.
Orange Krush II
08-31-2017, 10:18 PM | #27 |
slower than you
Yes, those are the ones you want.
08-31-2017, 10:30 PM | #28 |
The pads for the ZL1 and the Z06 are different sizes and shapes.
The radius at the bottom of the pad is different. I assume the width of the rotor ring is wider on the Z06. Which pad will work better using a Z06 Caliper and a ZL1 Rotor? Does the Z06 Pads make proper contact with the ZL1 rotor? Here are the sizes:
-BtrBimmer
