02-22-2016, 12:32 AM | #1 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
V6 headers ? Not!
It's been a while since i've looked at V6's. My last two cars were V8 camaros from the 3rd and 4th gens. But these pictures seem to indicate that GM has tossed the exhaust manifold as a bolt on piece to the V6 and it looks like that's built into the block and all you get to bolt on is the collector back.
First time i've seen something like this. On the plus side, i guess it cuts down on the decision to ditch manifolds for headers since you dont really get to choose. Definitely makes wrapping easy if you decide to go that route (if i did, i'd paint with high temp paint first to avoid rust) |
02-22-2016, 09:32 AM | #2 |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Yes, the manifold is now built into the head. Some folks are calling it a "headifold". Chevy went this route with the LFX engine in the 5th Gen Camaro. As soon as I saw it, I said "man, you can bolt the turbo right to the head!".
That is exactly what GM did with the current ATS-V's (and other engines) LF4. The turbo bolts directly to the head and block. Oil and coolant can flow from the block to the turbos. Pretty cools setup, but you won't be able to install headers. |
02-22-2016, 10:47 AM | #3 | |
Drives: Car Join Date: Jun 2010
Yup... Not a new thing and many have looked at it with the O.O look of "wow, turbos like right to the head" If it works, I'd be totally fine w/ not needing to worry about the cost of headers to improve performance. |
02-22-2016, 11:54 AM | #4 |
Yea, should make turbo kits pretty simple, probably simpler than a supercharger kit (though you'd need two turbos).
Yet they'll probably still cost over 5k for the kits. Funny how the price for superchargers/turbos have stayed roughly the same in the past 10 years. I guess the tech improves at exactly the same rate as cost. |
