01-08-2016, 10:26 AM | #1 |
Retired from Car mfrs....
what bolt head is this?
01-08-2016, 10:52 AM | #2 |
Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
No clue....never seen it before. I used a torx head socket to get it out. Wasn't exactly the correct fit but it worked.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
01-08-2016, 11:22 AM | #3 |
exactly what I'm gonna do...thanks....Ive never seen this before too....LOL
01-08-2016, 08:00 PM | #4 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Sometimes those were used on the bottom of the LFX intake manifold. There are a couple bits you could buy that might work, Triangle, or maybe a Tri-Groove...
I've stripped them out a couple times using a torx bit. Usually what I do is take a flat blade screw driver, put one end into the point on the triangle, and the other end will go into the slot. |
01-08-2016, 08:06 PM | #5 |
Thanks.....got it with a torx , but i will replace with hex stainless then flat black it soon....
02-13-2016, 01:36 AM | #6 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
A CR-V4 is the best fitting, non striping security bit to use.
02-14-2016, 04:16 PM | #7 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Hah.. i just asked this question on the external/internal appearance mod forum. Trying to take my cover off to paint it and saw this bolt and was like....WTF.
