TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 09-17-2018, 08:03 PM   #1
4ME2DRV
4ME2DRV's Avatar
Drives: 2015 Camaro SS
Forgot to change the oil filter
I searched the forum with no results. I have a 2015 Camaro SS with 25k miles on it. My last oil change was at 19k miles about 10 mths ago with Mobil 1 5w30 oil and a Mobil 1 Extended Performance oil filter. I just changed my oil yesterday with Mobil 1 oil, but forgot to put on a new filter. Do you think I'll be ok for another 3k-4k miles or should I change it asap....or what suggestions do you have?? Thanks
2015 Camaro SS
4ME2DRV is offline   Reply With Quote
Old 09-17-2018, 08:05 PM   #2
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I'd Switch out the filter and replace the qt or so of oil back in.
chuckie669 is offline   Reply With Quote
Old 09-17-2018, 08:08 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
^^^this
In the future you should change your oil and filter at least once every 12 months no matter the mileage
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-17-2018, 11:07 PM   #4
SharpOldNo7
SharpOldNo7's Avatar
Drives: 2015 2LT RS Convertible
To each his own but I just put 10,500 Miles in my F150 and 7,500 on my Camaro. I only have a V6 in my Camaro but the filter is good for 15,000. If you had run a Fram in it I would say change it but the filter media in a Mobil1 filter can withstand the extended mileage.
SharpOldNo7 is offline   Reply With Quote
Old 09-19-2018, 08:10 AM   #5
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
A filter would never have a longer interval than the oil. If filter not changed, xx percent of old oil left in...didn't really change all the oil.
On some applications... not passenger cars or trucks... the filter is changed more often than the oil. Such as fleet HD applications where oil life analysis testing is done showing the oil additive package has much life left beyond the filter change interval. But not the other way around.
If I were in the OPs shoes... I'd change the filter +1 qt, and shorten up the next change to 3k due to this one was botched and didn't really put in 100% new oil. The oil that is in there does not actually have 100% OLM life, due to old oil being mixed in.
Russell James is offline   Reply With Quote
Old 09-19-2018, 08:39 PM   #6
4ME2DRV
4ME2DRV's Avatar
So on my 2015 Camaro SS, I should be able to swap out the oil filter without all the oil pouring out?
2015 Camaro SS
Old 09-21-2018, 11:02 PM   #7
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
A lot of oil will come out, but it should stop. Fill the new filter with oil before installing.
wakespeak is offline   Reply With Quote
Old 10-23-2018, 01:01 PM   #8
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
If you religiously change the oil on time and use a good oil, dont panic. If you have an abused engine and the oil comes out black and burnt smelling, change the filter.
For peace of mind, change the filter. Most filters can handle skipping an oil change or 2.
canadian ss is offline   Reply With Quote
Old 10-23-2018, 03:03 PM   #9
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
It's cheap insurance, if you are doing it yourself, just change it out and fill the car back up until it's where it needs to be on the dipstick.
What are you out? A little time, $35 for 5 qts, and a filter? Unless you still have leftover oil from the car needing 8.
Chalk it up to a lesson learned, and you won't make that mistake again.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 10-23-2018, 04:35 PM   #10
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I would just spend the time and twist the filter off, have the new one handy and twist it on to minimize spilling. Refill till dip stick says full, and done.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
