Old 07-26-2018, 10:21 PM   #1
ruka80
Drives: 2010 SS
Exclamation wtf is this?! 😮
On break at work today, i noticed this strange piece of thick fabric hanging from my drivers side wheel well. It was halway coming out, so i tugged at it a little bit until i got it out. I have no clue what this is, how it got there, if it was from the inside of my car.. And what purpose it served. If anybody has any idea, please let me know. Im curious.
ruka80 is offline   Reply With Quote
Old 07-26-2018, 10:27 PM   #2
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
That is sound and heat type insulation. I don't know where it is on the camaro. Something not covered in metal I would expect to be attached to the bottom of the hood or under the dash or carpet. If you aren't missing any under the hood I'd guess the car in front of you is now.
silversleeper is offline   Reply With Quote
Old 07-26-2018, 10:31 PM   #3
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
inner fender by door hinge?
Cyber/Orange10 is offline   Reply With Quote
Old 07-26-2018, 11:19 PM   #4
gringo
gringo's Avatar
Drives: Camaro V6
It looks like either the front fender to door seal or the sound deadner for the wheel well housing. However, the front fender to door seal on mine is foam material, not pressed insulation backing like that one.
gringo is offline   Reply With Quote
Old 07-26-2018, 11:48 PM   #5
94z28inok
Camaro- Life Member
94z28inok's Avatar
Drives: 15 Camaro 2SS/RS, 19 Tahoe
Send a message via Yahoo to 94z28inok
It should sit at the back of your front fender on the inside vertically. Meaning not where you can see it with the door open, but other side of the back of the fender. Hope that makes sense, 13 hour work day plus 3 hours paperwork and night time meds.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl
19 Tahoe 5.3 Boring Grey
91 Camaro RS 305 TBI 700R4
85 Corvette - TBD
05 Envoy 4.2 4x4
94z28inok is offline   Reply With Quote
Old 07-27-2018, 05:53 AM   #6
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Thats from nowhere on the outside of the car.Did you run over something.
rontammy0 is offline   Reply With Quote
Old 07-27-2018, 06:39 AM   #7
copoz28
copoz28's Avatar
Drives: 2010 2SS-RS, IOM, M6
Its something you ran over there is no material like that on the bottom of the floor board on the outside...OR is your floor board rusted out where its coming from the inside ?
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter,
DynoTech Driveshaft, E2X Catch Can .
copoz28 is offline   Reply With Quote
Old 07-27-2018, 06:50 AM   #8
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Take your inner wheelwell spash shield off and put it back in there. It's insulation between the wheel opening and door.
Russell James is offline   Reply With Quote
Old 07-27-2018, 07:06 AM   #9
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
This guy has the right answer. When I put my 3-D carbon vents in. The back side of the front fenders near the doors in the wheel well is where that is from.
BLU DUCE is offline   Reply With Quote
Old 07-27-2018, 07:09 AM   #10
BLU DUCE
BLU DUCE's Avatar
Fender vents
Old 07-27-2018, 08:46 AM   #11
gringo
gringo's Avatar
Drives: Camaro V6
Open the door and look inside the front fender. You will see something black in there and that will be the inner fender liner insulator.
It may be black foam like mine. The early cars probably had that hood insulation type material and then they changed to the foam sponge like stuff on the later models.
Old 07-27-2018, 08:57 AM   #12
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
Thought it was a rat at first quick glance
rvnmaniac is offline   Reply With Quote
Old 07-27-2018, 09:31 AM   #13
SquawkVFR
Drives: 2010 Camaro
..or a sail rabbit.
SquawkVFR is offline   Reply With Quote
Old 07-27-2018, 03:16 PM   #14
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
Bingo!
2011 Vert - 2SS/RS 6spd Triple Black
DaddySS is offline   Reply With Quote
