12-02-2023, 03:04 PM | #1 |
Cap LT4 Blower/Head Bolt Holes with Edbrock 2650
This is likely only relevant to the rare someone searching the web for the answer.
When I recently removed my Edelbrock, I discovered that it uses two fewer bolts than does the OEM blower. Therefore, you have to cap two (2) OEM blower bolt holes (#1 and #8) when changing to the Edelbrock 2650. Edelbrock does not mention this situation. Vapors were escaping the crankcase through the unused bolt holes into the valley. I have a MM, so the oil wasn't too bad, but it's not something you'll want.
'20 ZL1 1LE A10,
