10-05-2017, 02:33 PM | #1 |
Drives: Arctic Blue 2SS Join Date: Oct 2017
Snow tires for SS?
Does anyone have experience driving the SS in the snow? Here in Illinois we may get a lot and we may get none, you never know. Just want to get some info on what others are doing about tires.
10-05-2017, 02:36 PM | #2 |
Drives: X-15 Velocipede Join Date: Mar 2008
When I lived in Vermont, Bridgestone Blizzaks saved me over and over.
Turned car into snowplow. Alas, I'm back home in FL and gave my set of Blizzaks away. btw - got wheels and tires shipped from tire rack, mounted, balanced - ready to put on car..
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
10-05-2017, 02:58 PM | #3 |
Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC Join Date: Jul 2016
I had them last winter in Michigan. Car did fine, no problems in the snow. I went with 18" Blizzaks.
10-05-2017, 03:01 PM | #4 |
10-05-2017, 03:03 PM | #5 |
Thanks for the info! I wish I was down by Florida! Hopefully one day I'll be in Tennessee livin the dream and not worrying about snow!
10-07-2017, 01:43 AM | #6 |
Drives: 2023 2SS1LE Join Date: Feb 2017
doesn't that set your speedometer off with using 18 inch rims?
10-07-2017, 05:28 AM | #7 |
10-07-2017, 05:33 AM | #8 |
Just as you can "plus" size wheel/tires you can "minus" size as well. In other words, you can increase or decrease the wheel diameter then change the aspect ratio of the tire so that the actual diameter of the tire remains the same regardless of the wheel size. Will it be exact? Sometimes but even if it's off a bit it will not throw your speedo off by much. You can use a GPS on a flat stretch of road to get a pretty accurate reading of your speed after the switch. At leas this has been my experience and how I checked to see how close my speed was after the switch. |
10-07-2017, 06:15 AM | #9 |
Drives: 2017 Camaro 2SS - M6, NPP, MRC Join Date: Jan 2010
I went with Goodyear Eagle GW3's when I had my 2010 1LT, but for my '17 SS I went with Blizzak WS80s on 18" wheels. Got the same wheels as another forum member (Sport Edition P2s, I believe they're called) since he'd already confirmed they fit over the standard SS Brembo calipers.
Haven't had reason to try them yet, still far too warm, but all set for around Thanksgiving when I typically put snow tires on. Make sure you get the TPMS relearn tool. |
10-07-2017, 10:43 PM | #10 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
did this.. Ontario winter.. zero issues.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
10-07-2017, 11:13 PM | #11 |
Drives: 2017 SS Join Date: Aug 2014
hmmm I just put mine in the garage until spring and drive the Subaru for the winter. Although the 2012 1LT did quite well on slick roads the few times I did drive it in winter. I have since upgraded to the 2017 2SS. It will never see snowy roads.
10-07-2017, 11:49 PM | #12 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Yep went with 245/50/18 Blizzak WS80's on seperate 18" wheels and had no problems. Even driving through a couple inches of snow it just plowed right through it with no problem.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
10-08-2017, 07:34 AM | #13 |
Drives: 2017 1SS Blue Join Date: Mar 2010
I live in St. Louis. I removed my summer only tires and replaced with all-season. Under 2 inches I get around fine. Over 2 inches I take my wife's car.......... Bottom line, a good all season tire should serve you well.
10-08-2017, 05:15 PM | #14 |
Drives: 2019 ZL-1 Join Date: Feb 2009
I have 18" Michelin Ice3X- just need 18 inch wheels......
2012 Yukon XL Denali w/ 6.2 AWD Last edited by avalonandl; 10-10-2017 at 11:12 AM. |
