07-06-2017, 02:49 PM | #1 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
so many ask me why I suggest this
Ive always recommended keeping intake duration below 230*
This is why: https://youtu.be/9LTDHiUftlU By what Ive seen on a street car 230* is the breakover point for the most part of losing too much bottom end and off idle torque for real good low rpm driving and ease of tuning. This not always the case because of cam design tweaking and real good tuning but for the most part this is why.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
07-06-2017, 04:50 PM | #2 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Great show!
Sent from my iPad using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
07-06-2017, 05:04 PM | #3 |
I cannot get enough of Freiburger. Really smart guy.
I wish they were able to release these more frequently. Engine Masters & Roadkill are fantastic.
07-06-2017, 05:52 PM | #4 |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
Thanks for these... great info and show!
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
07-06-2017, 07:15 PM | #5 | |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-06-2017, 09:24 PM | #6 |
Coughing... clearing my throat over here.....
Cant wait for fest!
07-07-2017, 07:35 AM | #7 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: Apr 2011
Thanks for sharing the link.
2010 2SS/RS M6 SIM Pedders Coilovers , Sway Bars & Cradle Bushings. Lowered 1-1/4. GFX Pkg. Led Fog Lights & Side Markers. CAI. DT gCat Back Exhaust. Heritage Grill.
07-07-2017, 10:00 AM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Freiburger rules! Love that they dumb it down for us shade trees.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
07-08-2017, 10:18 AM | #9 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Most ramping on a roller camshaft is much wider than a flat tappet cam helping out the roller, what they call high lift is more inline with the stock camshaft in the ls engine in its specs as far as lift though the stock bumpstick has a lot of LSA and low duration I would just like to point out. They also don't go into adding advance into the LSA or other important things to consider, but they are good at doing a comparison. Choosing a milder cam for the street myself is a choice I made until I have money for other supporting mods as yes Money matters, better anything can so much add costs.
As far as the lifts most use for a mild LS camshaft the .600 and just under area for intake and lessor for the exhaust for lift along with longer duration for the exhaust to clear out the gases is the case for a good daily driving cam shaft as far as torque curve and the engine vacuum but comparatively many will not notice much difference IMO in the drivability with a larger cam unless its much larger... much larger as most LSA are pretty close in cams, their duration was Huge in the test more inline with a stroker cam shaft for the "larger" cam even beyond what Tick calls the Polluter cam and I believe the duration to be in excess for the lift often a thing people do for a tight LSA to get a more healthy flow and more exhaust sound with the lope. I daily drive my car, I wanted low end grunt and went milder than my last cam with its more duration and higher lift and tight LSA. I did stroke it though and the low end torque makes all the difference in the world where I drive on the street and its easier on the valve train. The difference in driving feel though from a 235/239 .629/.623 112 lsa to a now 228 / 234 .613/.578 114+4 is damn near not felt....IMO But not just reaching for the high end HP I desire more friendly until I can afford better as in intake; airforce , maybe ls7 small bore heads for the intake also a must and a 102 other than that I will stay with the stock CNC ported because its cheaper by far and may just have to be with a fast intake for the results costs so much more.... but either way I go the cam will be a stroker cam that can use the much larger duration in a way to get the flow into the larger chamber made by stroking without going insane on lift and spring pressure and I imagine it will sound even healthier and of course the numbers will rise but shifting all the power to the top end.....Not Really that useful for the daily driver /street strip car, and as that tests shows .....the torque did not change that much and that's what moves you in a heavy Chevy. Just my rambling, have a nice day good clip Bo. And yes I will take having higher torque than my HP any day..LOL Its totally a different beast with a stroking versus just camming the heck out of it.
07-09-2017, 10:46 AM | #10 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Great cams 101 for us novices. Do they have any vids explaining VVT?
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
11-17-2017, 08:44 AM | #11 |
Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
Bo, are you saying 230 in the context of stock CI? Wouldn't that number change a bit if we were talking about 416 CI, because all things being equal, VE would be better at low speeds? Then again, I guess that would still be dependent to some degree or another on the cylinder head being used, among other things.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* |
11-17-2017, 04:24 PM | #12 |
Correct the larger the engine is the more duration ypu can run with good low end power.
11-18-2017, 09:15 AM | #13 |
So that would be true assuming either same or similar cylinder head flow characteristic, right? (ie....purchasing a stroker short block and re-using LS3 heads). But if you went to an aftermarket cylinder head with a larger(need to quantify that) cc intake runner, would you effectively be back to your original point. In other words, again, depending on the design and size of the cylinder head, if the larger cylinder head has less velocity at low lift due to its additional size, would you not find yourself back in the same position that you were highlighting? I hope that makes sense. And I realize that I'm kinda stepping into a HUGE gray area here but Im just looking at the general principle.
11-18-2017, 09:20 AM | #14 |
Yes. Gray area.
