View Poll Results: Which front end for my car? | |||
A. 2012 1LE splitter painted gloss black with JPSS V4 Aero | 4 | 22.22% | |
B. ZL1 front bumper with plastics painted gloss black and JPSS V4 Aero | 7 | 38.89% | |
2014+ front bumper with Z/28 splitter and JPSS V4 Aero with fender flares | 7 | 38.89% | |
Voters: 18. You may not vote on this poll |
Thread Tools |
08-02-2016, 09:13 PM | #1 |
Drives: 1sadclutch Join Date: Dec 2012
2012 VR 1SS/RS Track/Street Thread :)
Last update: 05/18/18 Legend: Planned | Purchased | Installed Engine / Powertrain 1.TSP 2010+ Camaro SS & ZL1 304 Stainless Steel 1-7/8" Long Tube Headers w/ Off-Road Polished Connection Pipes & Exhaust Manifold Gaskets, Incl. O2 Ext. 2.Corsa Camaro ZL1 Stainless Steel Exhaust Black Diamond Tips 2012-2014 3.DEI coil boots. 4.Synergy Motorsports custom tune 5.Detroit Truetrac 912A686 Helical differential 6.Z/28 rear differential cooler (23216684) Interior A1. TWMPerformance 7 competition-series-shift-knob A2.Proven Wicked 020001 Steering Wheel Hub Adapter A3.Sparco 015R98TU Quick Release Steering Hub Adapter A4.OMP Superquadro Racing Steering Wheel - Flat 320mm, Black Suede A5.Racepak IQ3 Mounting Bracket A6.Racepak 250-DS-IQ3 Display Dash A7.Racepak OBD II V-Net Interface Cables 280-CA-EFIOBDII A8.Racepak V-Net Connector Modules 230-VM-EFIUCAN A9.Racepak Analog Pre-Programmed V-Net Modules With Sensors 220-VP-PT-OP150 A10.Racepak Analog Pre-Programmed V-Net Modules With Sensors 220-VP-TR-OIL A11.CLS3OS GlowShift oil filter sandwich A12.Rear Seat Delete A13.Remove carpet Handling B1.23105018 Lower Control Arm B2.23105019 Lower Control Arm B3.23105014 Lower Control Arm B4.23105015 Lower Control Arm B5.23104902 Arm B6.23104903 Arm B7.23104900 Trailing Arm x2 B8.22845487 Link Rod x2 B9.20942237 Lower Control Arm x2 B10.22761221 Stabilizer Link x2 B11.22842516 Link B12.22842515 Link B13.Knuckle 23129155 x1 B14.Knuckle 23129156 x1 B15.Bilstein Heavy Duty Shock & Strut for Camaro - 35-245728, 35-245735 B16.Bilstein Heavy Duty Shock & Strut for Camaro - 24-222976 x2 B17.DSE Drop Spring 1.5" Drop - P/N: 031131 @ 220 lbs/in. x2 B18.DSE Drop Spring 1.5" Drop - P/N: 041812 @ 425 lbs/in. x2 B19.Z/28 Fender Flares B20.Z/28 Side Skirts B21.22893907 OEM Black Zl1 Grille B22.JPSS V4 Aero Front/Rear B23.SLP 100039A Front Lower Splitter B24.JPSS Camaro 2010 - 2015 5th Gen Sway Bars B25.JPSS Black Magic Caster Locks B26.JPSS 2010 to 2015 Camaro Black Magic Extended Range Camber and Caster Bolts B27.JPSSCamaro 2010 - 2015 Billet Radius Arm Bushing B28.Pegasus CNC Solid subframe bushings. B29.Pegasus CNC Camber plates. B30.CTS-V Camaro SS ZL1 Z28 Wheel Hub Bearing New OEM 25954415 B31.Longacre Spoiler Support 23706 x2 Tires C1.GOODYEAR EAGLE F1 SUPERCAR 3R 305/30ZR19 C2.Yokohama ADVAN SPORT V105 - SIZE: 305/30ZR19 C3.Pirelli P ZERO TROFEO R - SIZE: 305/30ZR19 Wheels D1.6x Z28 Rear Wheel 19x11.5 22873227 D2.4x Z28 Front Wheel 19x11 22873225 D3.ACDelco 20964159 GM Original Equipment Tire Pressure Sensor with Cap, Washer, and Valve Kit Brakes E1.J&M 2010+ CAMARO FRONT AND REAR BRAKE HOSE KIT E2.FRONT 6 PISTON AND REAR 4 PISTON BREMBO CTS-V CALIPERS Pads F1.G-LOC R18 Front F2.G-LOC R16 Rear Rotors G1.ACDelco 177-1145 G2.ACDelco 177-1146 G3.ACDelco 177-1051 GM Original Equipment Rear Disc Brake Rotor x2 Fluids H1.Engine oil: Mobil 1 15w50. H2.Differential oil: Genuine GM Fluid (88900401) 75W-90 Synthetic Axle Lubricant - 1 Quart H3.Genuine GM Fluid 88900330 Limited Slip Axle Lubricant Additive - 4 oz. H4.Transmission oil: Amsoil Signature Series Multi-Vehicle Synthetic ATF. H5.Castrol SRF Racing Brake Fluid H6.Coolant: GM DexCool @30%. H7.Power Steering: Motul Multi ATF Synthetic Automatic Transmission / Power Steering Fluid H8.Drain Plug: Napa Magnetic Drain Plug 704-1903 M12-1.75 Filters I1.Napa Gold Cosmetic J1.AnzoUSA ANZ351002 Gloss Black Taillight Bezel J2.Avery Satin Black Vinyl AutoImageCustomInc. ___ Last edited by AndrewHolm; 08-06-2018 at 10:20 PM. |
08-02-2016, 09:41 PM | #2 |
Drives: 2013 2SS (sold) Join Date: Jan 2016
Cool, it'll be fun to follow along!
I really need to start my build thread too, I'm pretty far in lol.
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
08-02-2016, 10:22 PM | #3 |
Thank you! It's mostly rigged from X25's parts list epica but I added a few new pieces gathered from L99CAMA2011's experiences. Credits to Justice Pete. Cheers.
08-02-2016, 10:55 PM | #4 |
Drives: Camaro 1LE Join Date: Nov 2015
Nice! Good to see a Bay Area Camaro build. Looking forward to seeing your build progress and hopefully seeing you on the track sometime!
08-03-2016, 12:51 AM | #5 |
Yep I'm going to use x25's format also, he's a local friend and will be in my build thread lol
08-03-2016, 01:16 PM | #6 |
Luckily I don't drive in traffic with the Camaro often. I hate sitting in traffic with a passion lol. So I usually drive early morning or late evening. Coming back from Marina on Sunday evenings is probably the most traffic and it's not too bad luckily. Some groups are really good about starting earlier on Sundays and ending their events earlier like 3pm. There are two routes back home (through Gilroy or Santa Cruz).
08-03-2016, 02:49 PM | #7 |
Not really, x25 used his stock 1LE suede steering wheel, and I just bought the same to put on my car. Since my car is also my DD, I didn't to lose airbag/steering controls functionality with some of the "racing" wheels
11-08-2016, 11:59 PM | #8 |
11-09-2016, 09:24 PM | #9 |
Drives: 2014 1SS Join Date: May 2014
Man that Corsa exhaust looks good.
11-10-2016, 03:47 PM | #10 |
Drives: 2015 camaro 1le Join Date: Jun 2015
I will be following along. I liked x25s build. Fellow washtonian
03-05-2017, 08:31 AM | #11 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Nice build, I can't believe I missed this. What got me here is your APEX wheels. In the pics above, what camber are you running? Are you using any wheel spacers?
03-15-2017, 06:36 PM | #12 | |
I'm looking at a few different wheel for the track. I found some Rays/Volk racing ZE40s. Super light, forged and great looking, but the 19x11's where a one time manufacture and ther are not any left in the offsets I want.
03-16-2017, 12:06 AM | #13 | |
https://www.apexraceparts.com/wheels...s-7-wheel.html Last edited by AndrewHolm; 03-16-2017 at 09:40 PM. |
03-16-2017, 05:59 AM | #14 |
I've seen the Z/28 wheels around every once and a while. I am on the group buy list for the ET44 ARC-8/EC-7 Apex wheels. I just started looking into some CCW's also.
