11-25-2018, 06:05 AM | #1 |
Drives: 2017 Camaro SS Join Date: Nov 2018
Convertibles and car washes
Here in NJ we had heavy rains that should have washed most of the salt off the roads and the temperatures will be above 50 degrees. The Camaro will be coming out of the cave.
At the end of the day I'd like to take the Camaro to the car wash, mostly for the undercarriage wash. Are there any cautionary tales about taking a convertible through an automatic car wash?
Kevin
Luceo Non Uro |
11-25-2018, 09:14 AM | #2 | |
The Beast
Don't do it
11-25-2018, 10:47 AM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
There are a few completely touchless car washes here that don't have the tire guides and I will occasionally go there. Unfortunately they bundle the belly blaster in a package with other items like spray-on wax that I prefer not to use on the convertible top. I will probably build or buy a belly washer to use at home for this reason. Check the car wash to see what they include and decide if you want the package.
11-25-2018, 11:01 AM | #4 | |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Don't leave the top down. Make sure it is up....J/K!!!!!!!!!AAAAAAAAHHHHHH!!!!! |
11-25-2018, 11:16 AM | #5 |
Retired from Car mfrs....
Run it thru a touchless wash, protect the top with RAGGTOP or 303 products...google them...
11-25-2018, 01:55 PM | #6 |
You could invest in a good power washer, they are worth the money. You can drive it and before you put it away wash off underneath and put it away. There are different pressure nozzle, use the wide spray nozzle and you can do a really good job underneath. To even do a better job run it up on some ramps or jack it up on one side and you can get all of it off.
11-25-2018, 02:19 PM | #7 |
Drives: 2017 Fifty 2SS Convertible Join Date: Aug 2016
My vert is dusted after each use, for my other cars, I use a long handle soft brush in the cold months, also here in NJ
2017 2SS 50th anniv. vert.
2017 Jeep Laredo Altitude 2018 MB GLE350 |
11-25-2018, 04:25 PM | #8 |
376 cubic inches of fun
Car wash? Car wash?
No way am I putting my Camaro through a car wash...and it's not even a convertible. The OP mentioned that their Camaro is in a cave for winter. That's a good place for it to stay until sand and salt season is over. |
11-25-2018, 04:48 PM | #9 |
we bought a long metal tube(approx.2')that screws unto the hose and concentrates the water stream almost like a pressure washer.only cost like 10 bucks,and it would probably blast the salt off the undercarriage pretty good.
11-25-2018, 07:52 PM | #10 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I read a story about a guy obsessed with his car, ran it through the under carriage cycle at the car wash...turns out the water was recycled from previous washes.
Not sure if true or not, just funny.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
11-25-2018, 08:50 PM | #11 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
The ones around here filter and reuse the water.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
11-25-2018, 11:14 PM | #12 |
Drives: 2017 Camaro 1LT Convertible Auto V6 Join Date: Jul 2017
11-26-2018, 05:16 AM | #13 |
Drives: 2017 2SS Auto Join Date: Apr 2017
Ran my leased SS through an automatic car wash probably 50 times without issue. I wouldn’t recommend them for reasons that apply to any car including hard tops but had no issues with leaks or damage to the top if that’s what you are concerned about.
11-26-2018, 05:44 AM | #14 |
