03-16-2023, 03:35 AM | #1 |
2016-2023 Camaro COPO Style DS Carbon Fiber Hood
Styled after the great looking factory-built COPO Camaro hood this Anderson Composite 2016-2023 Camaro Carbon Fiber COPO Style Hood will give your Camaro the look of a COPO Camaro without the price tag. This hood features an enlarged forward facing air intake and a raised center section for increased room for engine modifications and hot air extraction. This hood has finished carbon fiber underhood bracing for great looks at your local show and weight savings for your local track events. Anderson Composites components are carefully hand-crafted using only the finest materials. Anderson Composites production team offers superior craftsmanship with many years of experience working with carbon fiber. Every component is constructed with a consistent weave pattern.Anderson Composites production processes allow exceptional carbon/resin ratio, creating high product stiffness that also leads to extra strength. For a stunning finish, our products are coated with a glossy clear coat that does not chip or flake. Anderson Composites meticulously inspect all of their components and stand firmly behind their products so that you can enjoy peace of mind with every genuine Anderson Composites product. *COPO STYLE WITH MORE AGGRESSIVE "COWL BULGE" *CARBON FIBER "SKELETON" BONDED TO UNDERSIDE OF CARBON FIBER HOOD - REDUCED WEIGHT *MESH SCREEN IS REMOVABLE & PAINTABLE *MOUNTS WITH OE HARDWARE *REQUIRES HOOD PINS FOR SAFETY REASONS *STRONGLY RECOMMEND THE USE OF A HEAT SHIELD *ANDERSON COMPOSITES DOES NOT SUGGEST RE-INSTALLING GAS SHOCKS/DAMPERS/STRUTS Fitment: 2016 - 2023 Camaro |
