02-20-2021, 06:34 PM | #1 |
Drives: Chevy 2019 Camaro 2ss Join Date: Feb 2021
Changed rim/tire size now T/C throws when not spinning
Hello all! Hope all is well & Someone can answer this!
So recently I upgraded rims and tires, yes I know the tires size difference is causing my traction control to trigger even though it’s not spinning, also my speed is actually 2mph faster than what’s showing (according to gps) however. My question is I currently run Front: 20x9 275x35ZR20 & Rear 20x10 305x35xZR20 My rear tires are new so I’d like to keep them. What would I have to change my front tire size to for this problem to be fixed? Thanks. Ps: I saw all the other forums on this but I couldn’t figure the tire size I would need to go to, my gues 275x40ZR20? Last edited by NateMaro; 02-21-2021 at 08:24 AM. |
02-20-2021, 11:20 PM | #2 | |
Hi Nate and
02-21-2021, 08:10 AM | #3 | |
02-21-2021, 10:22 AM | #4 |
Your mph is off because the rear tire is taller than stock. It’s covering more ground per revolution. Also, you might need to relocate the wiring harness on the rear drivers side. I know all of us with the SS and stock 9” wheels needed to when running the 305/35/20. It’s possible you’ve already worn through the wheel well and into the wiring harness causing the T/C issue
02-21-2021, 11:15 AM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
You have two separate issues. The first issue is that the difference in tire diameter between your current front and rear tires is almost 1". That is likely causing the traction control problem. Switching the front tire to a 275/40R20 might resolve this issue but could cause rubbing issues depending on your wheel offset.
As several others have pointed out the taller rear tire is changing your speedometer reading. A shorter rear tire would resolve this problem and probably resolve the traction control issue at the same time. Definitely check the rear wheel liner as suggested to see if you have damaged the wiring harness. There are numerous threads showing how to relocate the wiring harness to avoid rubbing. I'm running 20x9 255x40R20 front and 20x10 295x35xR20 rear. I like the slightly taller tires and I'm willing to live with the slight speedometer error in exchange for the slightly reduced wheel gap. I don't know if I needed to move the wiring harness with the new tires but I did it just to be safe. |
02-21-2021, 11:49 AM | #6 |
According to others here, the T/C issue would only happen if the front tires were taller than the rears. The reason is because your wheel speed sensors sense your rear tires moving faster than your fronts. So, you really shouldn’t be having any T/C issues. I run the 245/40/20 front and the 305/35/20 rear, so my front is .7 shorter than my rears. No issues at all.
02-21-2021, 12:51 PM | #7 | |
I read somewhere that the TC and ABS systems will tolerate up to ~3% overall (front+rear) deviation from stock, anything more and you may have issues. Sorry, I can't recall the source, but it does seem to apply in your case, as you've introduced a 3.3% overall bias (-0.4% front and +2.9% rear) vs the OEM setup. So, you can certainly try to bump up the front size to make the overall diff smaller, but then you can easily run into a strut clearance issue. I have only tested 245/40, 255/40, 275/35 and 285/35 in the front, and the last one was a really, really tight fit, I had added spacers to make sure the tire doesn't rub off the rubber grommets at the strut perch. In your case, even if you don't care about the esthetics of the speedo being almost 3% off, you'd still need something taller up front (at the very least 255/40, but then you might want to go a bit wider for better cornering grip), plus you may rub the wheel well liner with those tall rears, hence my suggestion of just changing the rears and sleeping well afterwards. At the end of the day, it's your call and your $$$
02-21-2021, 03:18 PM | #8 |
Okay! I appreciate all the help. I definitely understand more now and I’m going to see which route I’m gonna take. I have relocated the harness before I got these tire to be safe! Also for some reason my back up cam has gone completely out and will randomly come back on, hopefully that’s not on the same harness as the t/c.
Tags |
tire size, traction control, traction control lights |
