02-11-2021, 05:48 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
How do you guys mount your AEM Wideband?
I just bought my AEM Wideband. There must be a simple way to mount it. All advise will be appreciated.
02-11-2021, 05:56 PM | #2 |
They make a single defrost vent, dual defrost vent, single pillar, dual pillar. I went with single defrost vent.
https://jannettyracing.com/products/...-camaro-ss-zl1
02-11-2021, 05:56 PM | #3 |
If you mean the gauge face, I used a ZZP double pod along with my Banks iDash. If you mean the actual wideband, I had a bung welded into my header collector before ceramic coating.
02-11-2021, 09:00 PM | #4 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Mine is in the left side A/C vent. Even the dealer has missed it in the past.
https://smgspeed.com/product/2016-ca...onal-vent-pod/
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
02-11-2021, 09:26 PM | #5 | |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Little tip for the OP if you need a way to run your wideband I used the Sound tube plug which the ZL1 doesn't use. I shaved the tabs and drilled a 5/8 hole and used a grommet. Also I depined the plug to fit the wires through the grommet. |
02-11-2021, 10:10 PM | #6 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
02-11-2021, 10:16 PM | #7 | |
Drives: 2019 Camaro ZL1 Join Date: Dec 2020
02-11-2021, 11:32 PM | #8 | |
Clean setup. Thanks for the advice. I will go with the air vent option. But, here's the kicker, damn part is on backorder! |
02-12-2021, 03:18 AM | #9 |
There is a member on here that 3d printing the same mount for like $30. I bought one but never used it I'm sure if you do a search you'll find it. I'll look to see if I can find the members name.
02-12-2021, 06:39 AM | #10 |
Dyno Show Queen LOL
This is what I'm doing just waiting on my carbon fiber pillar dual gauge pod!
02-12-2021, 07:19 AM | #11 |
Drives: HBM ZLE Join Date: Aug 2017
Best place to mount the wideband sensor is the collector?
At that junction right now and appreciate feedback. Also gonna be using the dual pod a pillar mount |
02-12-2021, 07:26 AM | #12 |
Drives: '18 ZL1 1LE Join Date: May 2020
ZZP dual gauge pod here as well...
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
02-12-2021, 09:55 AM | #13 |
Drives: 18 ZL1 mostly stock Join Date: Jan 2020
widebands should be installed around 6"-8" after the collector to let the exhaust pulses merge to reduce the possibility of false readings. Some people say to install them even further back but it might take longer for them to start reading correct since they have to be heated up to work properly.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's |
02-12-2021, 11:50 AM | #14 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
First twin system I did way back when I put it right after the turbine housings, like many factories do. Well, after a year I went to pull them out & the gas cage had ballooned & they wouldn’t come out. Ended up having to cut them at the bottom of the threads. PITA. Morale of the story, there is such a thing as too close. |
