06-06-2020, 08:19 AM | #1 |
Drives: 2019 Camaro ZL1 A10 Summit White Join Date: Nov 2013
FS: LT4 Thermal Reduction Plates
Dyno proven HP gains
Isolate the supercharger from the engine Prevent heat soaking the blower Gain back ignition timing Stealth Installation Lets isolate the blower from the motor to stop the absorption of 110c (230f) engine heat into the blower, sounds like a good idea? and the blower spacers were born. THERMAL REDUCTION BLOWER SPACER PLATES Thermal reduction blower spacer plates help to reduce heat transfer caused by the supercharger sitting directly on the cylinder heads and spacing the charger up off the valley of the engine. The supercharger being in direct contact with the cylinder heads and sitting directly over the valley of the engine reduces thermal efficiency and heat is always the enemy in positive displacement superchargers. With the Thermal reduction plates the blower will operate significantly colder, reducing heat soak and increasing consistency. The air entering the combustion chamber will average lower temps and be denser, allowing a HP gain and when tuning more ignition timing thus again more HP. $450.00 New DM me an offer |
