03-13-2020, 12:52 PM | #1 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
4 piece Knee pads & Door insert piece.
I was thinking about getting the GM Factory 4 piece kit but they don’t come in the Shock colour. Plus they are very expensive over $600, can’t justify that. So I thought I would try out the GM Shock spray paint colour match on those 1SS plastic parts. First you have to have patience and don’t rush. Took be a total of four days to get it right, numerous repaints, wet sanding. So I roughed up the plastic first with sand paper, then cleaned them, then applied a bondable plastic primer. I let the primer sit and dry for half a day with two coats. I then sprayed the base coat with three sprays with 1/2 hour drying periods between sprays. I put them back in front of the fireplace for most of the day and let them sit to harden overnight. I had to wet sand trash and small bumps off, so some of them are done twice and some where done three times over. Next the clear coat, the most important to give it a shine and a harden texture. Same applies here, had to respray and wet sand until happy. The clear coat was best applied in light sprays to avoid runs, and put in front of fireplace. I used a pair of vice grips to avoid finger prints when spraying and when I put them in place to dry. Overall I can’t stress enough to go slow, if you think your going to spray once and it done your wrong. Hope this helps other think well maybe I can do this too, the worst I thought was if I didn’t like it I would just replace the plastic parts from GM. I also realize I am sure I am not the first to do this, I looked for another post to add to but couldn’t find one as similar.
Almost forgot, I added my stock GM fuel door to compare colour match in one of the pics. I did get the GM Black fuel door which I highly recommend the OEM one. Also I have a 3M clear bra roll left over from my front clear bra install and tried to fit it over the parts which would be great for added protection but I could not master that. Going to ask the wrap guy to do it for me.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
03-13-2020, 12:57 PM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
Nice job man! I appreciate when people make small custom changes to make the car their own.
03-13-2020, 12:58 PM | #3 |
Thanks man I appreciate your comment.
03-13-2020, 01:08 PM | #4 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Well Done. You did it right not to rush. Those paint jobs need a lot of patience especially if you’re not a professional painter.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
03-13-2020, 01:09 PM | #5 |
Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
Really good job!
What I normally don't like about painted interior pieces is the thought of them being too easy to smudge up with fingerprints, but it doesn't look like yours would have that problem because they're not a mirror gloss. Looking good! |
03-13-2020, 01:15 PM | #6 |
Thanks for comments and your right the finger print problem is real and that’s why I used the vice grips and waited a long time for them to dry in front of fireplace. Used soft cotton gloves to snap them into place.
03-13-2020, 04:20 PM | #7 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
That looks really custom and good. Nice job !
03-13-2020, 04:50 PM | #8 |
Thanks for comment.
Anyone out there with a Shock Camaro that needs a Custom Painted Engine Plenum Cover OEM in Shock colour. I have an extra one. It’s painted with bondable primmer, GM colour matched Shock base coat and 3 coats of clear. $150 shipped. RPI charges $269 plus tax and shipping. PM me if interested.
03-16-2020, 10:05 PM | #9 |
Drives: 2016 Camaro Join Date: Apr 2018
It looks very poor. It is much more effective to cover everything with double stitching leather.
03-16-2020, 10:17 PM | #10 | |
My next project. https://youtu.be/rFme6jPauJ8 Lol
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 03-16-2020 at 10:58 PM. |
03-17-2020, 12:06 AM | #11 | |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Shock pieces trimmed out look nice, the whole white paint effect does not. |
03-17-2020, 12:44 AM | #12 | |
Drives: 2LT RS Yellow Convertible Join Date: Aug 2016
Gold Rush
03-17-2020, 02:31 AM | #13 |
Drives: 2017 Camaro Join Date: Feb 2020
Very nice beast. did the camaro door covers come with car? if not where did you get it? i do not want the one that lights up. thx
03-17-2020, 09:48 AM | #14 |
It was an add on when ordered. Don’t plug them in I guess if u don’t want them to light up. If you go aftermarket the issue will be quality and you probably could find one that doesn’t light up.
