03-23-2015, 09:32 AM | #1 |
Drives: 2014 1SS/RS M6 Join Date: Feb 2014
What is wrong with my car?
Lately my car has been smelling like gas/rotten eggs, then it started overheating and the backfires have been a lot louder (see video). I'm going to the dealer tomorrow for the overheating part, they say it might be a bad thermostat but I was wondering if there is anything else I should be worried about. Currently not tuned with high flow cats and throwing codes P015d, P0420, and P0430 which I expected with the cats. https://youtu.be/IJ9tdKL2ATQ
03-23-2015, 10:21 AM | #2 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I am not able to look into those codes, but I associate the rotten egg smell with cat problems...a sulfur type smell.
03-23-2015, 10:33 AM | #3 |
Agreed. That sulfur smell is most likely cat related. The backfiring could be several things but it certainly isn't "normal". Could be a timing issue, a fuel/air mixture issue, a tuning issue, etc. Better have them check that out too.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-23-2015, 10:34 AM | #4 |
Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
Codes seem to be cat and o2 sensor related
03-23-2015, 10:39 AM | #5 |
Wouldn't the backfiring make sense with P015d?
03-23-2015, 10:47 AM | #6 |
Sorry... I don't know the code translations. I was just commenting based on previous issues with backfiring.
03-23-2015, 10:49 AM | #7 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Did you add extensions to your HFC's? These will help prevent any codes from popping. Might also want to check for exhaust leaks.
On the below pic, you'll note the extensions I purchased and installed for mine. You're going to get that smell with new cats on... not sure about the backfiring, though... this could be fuel/air mixture related. Definitely recommend a tune after installing HFC's, catback, headers etc. |
03-23-2015, 10:59 AM | #8 |
p015d is a 02 delayed response code
03-23-2015, 11:19 AM | #9 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
you realize they can void your warranty with high flow cats right? also it's a federal law violation to replace stock cats that are working properly. and now you want the dealer to fix this problem?
And best, their response will likely be replace the OEM cats and see if that fixes your problems. It's possible it's running lean with the high flow cats... causing it to overheat... burn up cats... and who knows what. If you don't have any other mods, I think you just need to tune it... which will likely fix most of your problems. |
03-23-2015, 11:30 AM | #10 |
I have a tune with my long tubes with hi flows and I have no code issues, the only issue I ever had was that I needed the tolerances for my 02 sensors changed as they were too tight and it kept throwing codes. I believe the code was that the 02 sensors were out of range.
03-23-2015, 12:34 PM | #11 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
well if they void the warranty just gut those things and tune out the sensor, but who knows what they will do at the dealership, hope the dealer is mod friendly
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
03-23-2015, 04:32 PM | #12 | |
03-23-2015, 04:49 PM | #13 | |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Especially a long dead cat. Yes, it will keep evil spirits and most people away, but boy does it smell bad.
03-23-2015, 05:46 PM | #14 |
Drives: 2010 SW Camaro 2SS RS 6M Join Date: Aug 2012
Maybe your old neighbor is having the last laugh...
