dave@hennessey
Old 10-12-2014, 06:36 PM   #1
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
LSA ( what parts are needed )
So just saying that if I wanted and I know there are other better setups. What would be needed to put this on my 1le? SS comes with zl1 fuel pump but would the fuel rails be big enough and injectors?
chevy 3 is offline   Reply With Quote
Old 10-12-2014, 11:31 PM   #2
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
Not sure on fuel rail but you would need new injectors
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 10-13-2014, 03:01 PM   #3
Spoolin
Drives: 2014 SW 1LE
You gonna buy an LSA motor and drop it in? Would be cheaper to just buy a ZL1.
Spoolin is offline   Reply With Quote
Old 10-13-2014, 03:08 PM   #4
Mikes fast ss
Slowhawk Built
Mikes fast ss's Avatar
Drives: 2010 Supercharged SS
Uses a completely different accessory drive. Not worth it imho.
9.21 @ 149 Slowhawk Performance
Mikes fast ss is offline   Reply With Quote
Old 10-13-2014, 05:57 PM   #5
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
If you got the money to buy an LSA motor, you could spend your money a lot wiser and have a nice setup!
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 10-13-2014, 06:23 PM   #6
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Why? You could do a lot more with your money.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 10-13-2014, 07:45 PM   #7
VOGGS-LS3-1LE
Angry by Nature
VOGGS-LS3-1LE's Avatar
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76
I have a zl1 supercharger if any one is interested, pm me.
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP
1 OF 76
Roto Fab CAI
1LE BADGES
VOGGS-LS3-1LE is offline   Reply With Quote
Old 10-14-2014, 06:37 AM   #8
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Just the blower, lid, injectors, pulley/acc belt drive, water pump and a/c compressor. You don't need the whole motor. If you keep the boost low...we all know the LS3 hangs on a good while. Total of all GM parts is about $4500. Most shops would charge about $1200-$1500 install with another $500ish to tune. Some blower kits alone are $8000.
Is it the best in terms of making big power? Def not, but it is very cost effective!
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 10-14-2014, 07:52 AM   #9
SilverSS1LE
OP said LSA, that doesn't mean just the blower and accessory drive. Or it would be called an ls3 with a blower. What makes an LSA special is the motor. And you can get great blower tuner kits around 5500. And install it yourself. A lot of the aftermarket blowers have way lower IAT's than stock blowers which means more efficient and less stress. And then have to worry about all the zl1 and cts-v blowers that are failing and having to get replaced or warranty work.
But OP if your looking to save your .02 there's plenty other blowers you can find used with very low miles and pick the complete kit up, injectors and all for around $4500. Not saying the blower for the LSA is a bad blower cause it's not and will support great power, but just do your research before you decide to pull the trigger. There's a lot of great information on here about the swap your wanting to do.
Old 10-14-2014, 12:36 PM   #10
TxBandit911
Call Me"Doc"
TxBandit911's Avatar
Drives: 2014 2SS/RS 1LE BLACK
I'm pretty sure the OP means the LSA blower, considering he asked about fuel rails and injectors.....
With that being said, doesn't Chevy performance parts have a LSA blower kit for the LS3?
TxBandit911 is offline   Reply With Quote
Old 10-14-2014, 05:48 PM   #11
chevy 3
NEcamaro5
chevy 3's Avatar
Sorry for the confusion but I was hoping for just the blower. Just would like to see what it would take to put this on my ls3.
I've been seeing more of them for sale as the years move on. Kinda would be cool to have Chevy stuff.
Old 10-17-2014, 05:40 AM   #12
davidcroft
davidcroft's Avatar
It's the isolator coupler in the snout that's failing. Swap the pulley and install a solid isolator coupler and you're good to go. The blower itself is fine.
The 8grand I was referring to was maggies and whipples, the other roots style blowers. The centrifugal blowers are considerably less, but they don't quite have that instant tq snap I'm looking for. Those stack boost on ya more like a Turbo.
There are a lot of different ways to skin a cat and everyone has their preferences. Hell the cheapest way to add 100 HP is spray...but then there's those pesky bottle refills, etc.
O.P. I say go for it...but I am biased because I'm about 85% done with gathering all the parts needed for my LSA blower install
Old 10-17-2014, 06:37 AM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Thanks Dave. I'm on it!!
I wish you luck on your build.
Old 10-17-2014, 11:11 AM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Most supercharger kits are over 7-8K $. I think the LSA is a hell of a deal.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
