09-27-2015, 11:55 AM | #1 |
Drives: 1963 Pontiac Lemans Join Date: May 2015
Anyone have wheel fitment numbers
Does anyone have wheel fitment numbers yet for the 2SS? Hard to build custom wheels without numbers. What is Pitch Circle Diameter (PCD), bolt circle and bolt pattern. Backspacing, offset, centerbore, brake clearance, wheelwall clearance.
10-17-2015, 06:37 PM | #2 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
Youd think with the embargo lifting yesterday we would be receiving some of this info now.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
10-21-2015, 01:27 PM | #3 | |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
From the Find New Roads thread...
http://www.camaro6.com/forums/showpo...&postcount=120 Quote:
10-21-2015, 01:31 PM | #4 |
Cant remember of the top of my head what was 2015 and earlier?
10-21-2015, 02:30 PM | #5 |
Drives: 2016 Red Hot 2SS M6 Join Date: May 2015
Can someone explain how I would figure out what offset to get on the wheels if I wanted to get 245 width tires all around with 19 inch rims and maybe a 45 aspect ratio? How would I know if they'll fit on the car?
10-22-2015, 11:21 AM | #6 | |
19x9"s (with around 38mm offset) will not give you a headache with clearance issues as the width of the tire at 245mm is still wider than the 9" wheel (227mm) you mount them on. --kC |
10-22-2015, 12:50 PM | #7 | |
10-22-2015, 12:59 PM | #8 | |
Shouldn't change much really. 35mm offset should still be in the sweet spot for the front as it's between 38mm (from the 18s) and 25mm (from the 20s) in the front. Depends on if the shocks are so physically different. I will be doing the same thing, from 20s to 19s, but my hands are pretty tied in offset that they cannot be any more than 7mm off from OEM (due to SCCA Autox rules). --kC |
10-22-2015, 01:23 PM | #9 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Well you'd want to know the clearances of the current car, and then you can use one of the tons of tire & wheel offset calculators out there.
I actually plan on taking some measurements Sat when I hit the Foxboro FNR. I hadn't considered going from 20's to 19's but up here in NE with our sh*tty roads, it's actually not a bad idea.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
10-22-2015, 02:09 PM | #10 |
10-22-2015, 02:22 PM | #11 |
going from 20's to 19's saves me like $400 for winter tires
How much do you guys think the stock rims weigh? Is a 22 lb rim light , heavy or in the middle? |
10-23-2015, 11:58 AM | #12 |
An OEM 20x9.5 is probably around 25-27 lbs if I were a betting man.
10-23-2015, 12:01 PM | #13 | |
I guess we'll have to wait and see...
10-23-2015, 12:10 PM | #14 |
The place I'm ordering from has fittment guarantee so... should be safe I think
