09-17-2017, 09:27 AM | #1 |
Drives: 17 Camaro lt, 22 Camaro LT1 Join Date: Nov 2016
$80 cold air intake
Awhile back I did a resonator delete tube and been wanting to take this project to the next step. My only problem is how to mount the maf sensor to the intake tube and how to mount it so it won't throw a cel. Here spectre makes an adapter tube in their 9405 3" adapter kit. I found it anywhere from $28 on ebay to $40 at box stores. It's a really straight forward install. Just 4 bolts to seat the maf sensor and bolt a filter on. Only other thing I did was cut apart a couple of adel's an bolt them to the rubber grommet (factory air box mount) and filter to keep some of the filter wobble down. Last step for this project will be to make a heat shield that will hold the filter in place.
All I can say is that this thing is really loud! Any throttle above 25% makes the turbo blow off and it spools louder than the stock exhaust. No cel's and the car sounds mean! |
09-17-2017, 01:14 PM | #2 | |
Drives: 2016 camaro 2.0t gray Join Date: Apr 2017
09-17-2017, 02:14 PM | #3 | |
Drives: Hyper Blue 2016 Camaro turbo Join Date: Aug 2016
Check it out . http://www.camaro6.com/forums/showthread.php?t=506492 Last edited by Beast-Y-Blue; 09-17-2017 at 02:26 PM. Reason: More info |
09-17-2017, 07:55 PM | #4 |
I've bought the expensive one's and made my own over the years. Honestly, I can't tell the difference in performance and its way more fun making your own.
Beast, that is a super nice intake setup you made! Love it when people take the incentive to make their own stuff! One problem I'm trying to solve though is how to mount it. What did you bolt the bottom too? I was thinking of making some sort of a riser bracket. If you have any pics of the bottom outside of the box (under the filter) I'd appreciate it. |
09-18-2017, 08:39 AM | #5 | |
