Old 03-01-2019, 11:53 AM   #1
HogmanZL1
HogmanZL1's Avatar
Drives: 2018 ZL1 Convertible
power bog during tight turns
I'm wondering if this is traction control, non e-LSD, software, or other and asking for other opinions. I have never driven the coupe with the e-lsd so not sure how that compares other then the obvious electronic benefits.
example- turning right onto an on ramp, rolling into throttle pretty hard, and power stalls until im almost straight then power back as expected. almost as if the engine is choked out. i am not noticing the traction control light coming on but will pay more attention next time it happens.
i know we have a lot of torque to manage, but it doesnt seem normal to have the power cut off completely like its doing to this degree. my RPMs are probably pretty low 2-3k when this occurs. maybe it wont do it if more aggresive in higher rpms.
I dont know. just thought i would ask because its annoying sometimes.
thanks for your input.
HogmanZL1 is offline   Reply With Quote
Old 03-01-2019, 05:20 PM   #2
Bigdog9586
Drives: 2016 Z06 coupe
Why not just go around the block and try it again with TC turned off.
Bigdog9586 is offline   Reply With Quote
Old 03-01-2019, 06:51 PM   #3
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Just an uninformed theory - do the nannies hold back the throttle if they see a hard turn in the convertible to avoid a potential roll over situation?
17rsvert is offline   Reply With Quote
Old 03-02-2019, 09:50 AM   #4
Bigdog9586
Which camera sees the turn?
