Old 11-12-2017, 10:49 AM   #1
POINTBY
Drives: 2020 ZL1 1LE
ZL1 1LE Jack Points
Due to the size of the side skirts on our cars the pinch weld can’t be reached without crushing the skirt. So, I’be been to multiple local stores looking for a hockey puck or something that will fit inside the notch in the skirt and hard enough to jack from.
Any ideas from others who have had theirs on a lift?
Thanks in advance.
POINTBY is offline   Reply With Quote
Old 11-12-2017, 10:52 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
See:
http://www.camaro6.com/forums/showth...32#post9972832
Old 11-12-2017, 11:00 AM   #3
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
https://zl1addons.com/products/jack-...nt=32532756929
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 11-12-2017, 11:14 AM   #4
POINTBY
So, I have to buy an aftermarket part just to lift the car. That’s ****ing stupid, Chevrolet!
And I guarantee you it’s because the base model Camaro weld points are easy to get to so the engineers didn’t think about the large side skirt on the 1LE being an issue.
Old 11-12-2017, 11:28 AM   #5
Bow Tie Affair
Drives: 6th. Gen ZL1
I have a set (4) pre-production ZL1 addons in black for sale. The pre-production lift points are not labeled with "liftpoint". They were used a few times and had antiseize applied to the screws, so no corrosion on the aluminum body. I would sell them for 55.00 shipped. Please pm me if interested.
Bow Tie Affair is offline   Reply With Quote
Old 11-12-2017, 11:37 AM   #6
bensf
bensf's Avatar
Drives: ZL1 1LE
My thoughts exactly lol
I used these initially https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
But ended up installing the product referenced by 17ZL1Camaro.
bensf is offline   Reply With Quote
Old 11-12-2017, 11:40 AM   #7
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Agreed that it annoying that we need to buy an aftermarket part to lift with a floor jack but I believe this is a problem with all the 6th Gen Camaro models. I have a 2SS and it has the same clearance issue with the side skirts.
Mark114 is online now   Reply With Quote
Old 11-12-2017, 11:42 AM   #8
Mr. Meh
Drives: Sold
Nothing to do with the 1LE specifically as even the base ZL1 has the same side skirt.
I got a cheap set of pucks from Amazon that have a frame rail notch.
They work just fine and aren't anywhere near as costly as the ZL1Addon bits.
Mr. Meh is offline   Reply With Quote
Old 11-12-2017, 09:28 PM   #9
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Yelp amazon cheap rubber puck. I bought for like $4. Works good
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 11-13-2017, 11:32 AM   #10
Mr. Meh
Drives: Sold
Sounds about right for the ones I got.
Old 03-24-2019, 02:15 PM   #11
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I bought the zl1 add on units last year; and only just now tried to use them.
the top side is uneven (up side).
the sheet metal at the pinch seam flange is even and they rock back and forth on the sheet metal.
Im afraid to use it now - I dont think they should be like this.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 03-24-2019, 02:34 PM   #12
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Take a vid if you can. Maybe that’s normal????
Old 03-24-2019, 03:32 PM   #13
1hprush
2018 ZL1 1LE
1hprush's Avatar
Slide them on the pinch weld as far as you can, they should be fine after you tighten them up.
1hprush is offline   Reply With Quote
Old 03-24-2019, 04:09 PM   #14
DeOz
Drives: 2019 ZL1 1LE
I agree its a bummer that Chevy made it hard to lift these cars. But those ZL1 add on lifting plates are a work of art. One of the first things I got for my ZLE and have already used them and they work great!!
DeOz is offline   Reply With Quote
