04-26-2019, 04:07 PM | #1 |
Drives: 2018 Camaro LS / 2018 Equinox LS Join Date: Mar 2019
Clutch Rattle at low speed on Camaro 2.0T
Hey Guys,
I have noticed a weird clunking sound coming from the clutch when the clutch is engaged or depressed. Only occurs while shifting between 1st and second gear. Anyone else noticed this issue on a Camaro 2.0T? It has barely 100 miles. Thanks |
04-26-2019, 06:14 PM | #2 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
That's not normal. Take it to the dealership.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
04-27-2019, 11:49 AM | #3 |
Yep took it to the dealer, waiting for them to get back to me.
04-29-2019, 04:55 PM | #4 |
04-29-2019, 07:40 PM | #5 |
Drives: 2016 2LT RS Blue Velvet Join Date: Dec 2016
Seems to happen to me all the time, almost any time I push in the clutch while in first gear, and more often when slowing down.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake |
04-30-2019, 09:56 PM | #6 |
How many miles does your have? I just got mine from the dealership and they said that its normal flywheel noise. Mine happens only when car is warmed up
04-30-2019, 10:29 PM | #7 |
Drives: 2018 Chevrolet Camaro LS Join Date: Jan 2019
This is completely nornal with the dual plate clutch or whatever clutch our cars have. If u shift 1st to 2nd at low rpm u will hear it in any m6 camaro. Shift at 2000+ or 3000+ rpm and u will not hear it.
I took my camaro in for the same reason lol. Get ur car back from the dealership! |
