03-04-2018, 09:03 PM | #1 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
V6 Axle Back 2.0 Compatibility
Just wondering if anyone can verify if a V6 axle back exhaust will fit/line up with the 2.0 exaust?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
03-06-2018, 03:12 PM | #2 |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
No clue. Have you tried asking one of the exhaust manufacturers? Aren't the V6's true dual? I know the I-4 has a single intermediate pipe that Y's to the dual mufflers.
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine, and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's race, religion, sex, sexual preferences, handicaps, or intellectual abilities. |
03-06-2018, 08:48 PM | #3 |
I asked MBRP about their V6 axle back and they didn't know if it would match up to the 2.0. I think I'm just going to check out the underneath of a V6 at the local dealership. Can't find any pictures of the underside of a V6 online.
03-08-2018, 09:43 AM | #4 |
Ia there a reason you're dead set on going V6 exhaust? Is there some benefit I'm not seeing? I haven't had my first cup of coffee yet, so maybe I'm missing somethingl
03-08-2018, 11:14 AM | #5 |
Im not dead set, I just got a quad tip diffuser and the only options are Mishimoto for the 2.0. (That's fine, I really like the way their cat back sounds). There are more options for the V6 axle back quad tip, Borla, MBRP (next month), and others. Just wanted to weight all of my options. (I don't want to deal with a custom exhaust from a muffler shop).
https://www.ikonmotorsports.com/fits...ssy-black.html
03-08-2018, 02:50 PM | #6 |
Drives: 2016 2LT RS Blue Velvet Join Date: Dec 2016
I'm quite sure that the V6 is true dual, but both use just one muffler, and they look identical. The only difference that I've seen is forward from the axle-back, while the axle-backs look identical. Take this with a grain of salt, as I'm only basing this off of what I've seen from other LT/RS cars out on the road.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake |
03-08-2018, 04:15 PM | #7 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
I guess it would depend on the axle back, or how far the cuts are from the suitcase muffler, as the suitcase has the same enter/exit locations. They should be identical all the way forward until the second set of hangars. I think someone mentioned Borlas quad tips only, fit the quad valance without modification to stock system.
03-08-2018, 04:35 PM | #8 |
I don't see why an axle back would differ between the two cars. They're just piping now axle forward is where the issue is.
04-26-2019, 06:35 PM | #9 |
Drives: 2017 2.0 summit white Join Date: Feb 2019
Axle back
I have a 2.0 and I just ordered and installed about 2 months ago a MBRP axle back for a v6. It all connected the exact same. It was 359 and had a muffler delete with resonators. It’s loud on startup but not on normal driving. I personally think it sounds great but yes the v6 and 2.0 exhaust at the axle is the same.
04-26-2019, 07:21 PM | #10 |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
I asked MBRP about one of their setups and here was their response:
Good afternoon Jorge, System S7038304 will physically fit your vehicle; however we have not tested it and have no idea what it will sound like. Thank you for your email. Have a great day! Cheers, Scott Robinson | Customer Service Representative| MBRP Performance Exhaust Phone: (705)788-2845 | Toll Free: (888)636-7223 | WWW.MBRP.COM |
04-29-2019, 06:48 AM | #11 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
There will be no difference in sound other than differing the model of exhaust. Whether it is made for a v6 or an I4 will probably have no differences. The V6 axle back stuff will fit. It gets different (as someone just posted) once you go forward from the rear wheels. Your car will sound like a 4 cylinder with an exhaust.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
05-20-2019, 10:37 AM | #12 |
Exhaust
This is the exhaust I purchased.
