11-05-2020, 07:12 PM | #1 |
MDRHRNT
Drives: 2019 Camaro SS Fireball Edition Join Date: Oct 2019
TR6 Misfires
2019 Camaro SS
D1X blower (6-8 psi currently), longtubes, e85, tune (obviously) Just changed my spark plugs from stock spark plugs (ac delco) to NGK tr6’s gapped at roughly .025-.028 Went for a drive and it had very rough idle, did a pull and it started breaking up at the top of the gear. Not to mention it feels soooo sluggish now. and no, i have not used the 2 step on the new plugs yet. What’s going on? I did my absolute best to make sure my wires went back into place correctly and deep enough. i do have new wires on the way, they’ll be here tomorrow and i will be putting them in. (taylor wires with thermal socks) So if that’s the problem, it will be fixed tomorrow. but if it’s not, then what? |
11-05-2020, 08:09 PM | #2 |
Drives: 2019 SS Join Date: Apr 2020
Do you have the car tuned for 85? Correct injectors, sounds tune related not plugs.
11-05-2020, 09:54 PM | #3 |
MDRHRNT
11-06-2020, 12:08 AM | #4 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Did this happen immediately after spark plug change? If so, reinstall originals. Maybe one of the new plugs is defective. I know, this would be the FIRST time a new part was bad. LOL!
11-06-2020, 09:31 AM | #5 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
Sounds like you've got a bad plug or wire to me. How'd it run on the old plugs?
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
11-06-2020, 10:13 AM | #6 |
MDRHRNT
11-06-2020, 10:14 AM | #7 |
MDRHRNT
11-06-2020, 01:04 PM | #8 |
MDRHRNT
Okay guys, can confirm that wires made no difference
11-06-2020, 06:30 PM | #9 |
Drives: 2017 Camaro 1ss A8 Join Date: Nov 2019
How long have you had the E in your tank? Maybe it’s an old tank of E85, or the E you put in your car might just be bad E. Since winters coming over here in Cali, ima go back to 91 for the rest of it. The E quality is usually not that good in the winter. I have a flex fuel kit and tune
11-06-2020, 06:49 PM | #10 | |
MDRHRNT
11-06-2020, 07:27 PM | #11 |
It can be spark plugs, spark plug wires, or the actual tune itself.
11-06-2020, 07:32 PM | #12 |
I was wondering if it was the E85, because I have left the same tank for over a month, and only drove the car 2 times a week during that month. One day I was driving and I heard a loud pop coming from my car with blue smoke (maybe the left over E on exhaust tips) which happened to be a misfire. So I just drove until the tank of E was close to empty put 91 and some Lucas fuel injector cleaner in my tank, and ran fine afterwards
11-06-2020, 07:35 PM | #13 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Did your old plugs do this?
If not swap them back in. If it goes back to normal buy some factory plugs & call it good. |
11-06-2020, 10:07 PM | #14 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
This sounds suspect. Your Tuner had another Camaro with the same issues. Provided no fix to either you or this “other” Camaro. Seems like a Tuner issue
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
Tags |
ignition, misfires, misfiring, problem, procharged camaro |
