09-03-2013, 06:56 PM | #15 |
Drives: 2021 1LE Join Date: Jul 2011
And how did you come by that price... 3 and some change is the best I have seen.
Sent from my DROID RAZR using Tapatalk 2 |
09-03-2013, 07:28 PM | #16 | |
Liv'n The Dream!
Ya, I'll double what he said. And an online vendor doesn't count. Then you need to find someone to mount, balance and all that which will put you at or above what it would cost to buy them from Discount Tire and the like.
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
09-03-2013, 07:49 PM | #17 |
Drives: 2013 Camaro SS2/RS 1LE Rally Yellow Join Date: Aug 2013
09-03-2013, 09:01 PM | #18 | ||
Drives: 2014 AGM 2SS/RS 1LE Join Date: Aug 2013
$70 mounted and balanced at Discount Tire for employees.
2014 AGM 2SS 1LE RS - On Order 8/23/13, TPW 9/9/13, Built 9/12/13, Shipped 9/17/13, At dealer 9/29/13, Received 10/4/13
2011 V6 DC 4x4 AT Tacoma 1985 NA MT 300zx |
09-03-2013, 09:56 PM | #19 | |
Drives: 2013 Camaro SS 1LE Join Date: Jul 2013
sorry $263 http://www.onlinetires.com/products/...+100y+vsb.html |
09-05-2013, 05:57 AM | #20 |
Drives: 1SS Join Date: Sep 2013
09-05-2013, 06:07 AM | #21 |
Sellin Chevy's since '06
What are the actual wheel's weights?
We know the 11s will not fit up front but has anyone tried mounting the 10" fronts on the rear? What if we could buy 2 more 10" rims and truly be able to rotate front to back for better tire wear
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
09-11-2013, 06:34 AM | #22 |
Liv'n The Dream!
I've been looking for alternate sizes to use which may be more affordable and strangely enough I found a much larger tire for less money.
What I really want to know is: Will 315/35ZR20 XL110 fit our cars? I'm thinking they'll fit the backs but probably not the fronts. These are only one step up from the stock size on the back of the ZL1. These tires have a 60,000 mile warranty on them and cost $233 each at Discount tire. http://www.discounttire.com/dtcs/fil...=prca&toggled=
09-11-2013, 07:14 AM | #23 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
09-15-2013, 04:05 PM | #24 |
Loves Camaros
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert Join Date: Sep 2012
I had one of my tires remounted the other day for a tire repair, so I examined the rim and found these factory chalk marks on the inside of the wheel. I dunno what they mean, but it's interesting. 30 years from now someone will want to restore and place factory looking chalk marks back on it...
Old and new, sharing space!
09-26-2013, 02:55 PM | #25 |
Chasing the horizon
Drives: 2013 Freightliner Join Date: Nov 2009
Anybody know the offsets front and back?
09-27-2013, 09:26 AM | #26 |
Drives: 2013 2SS 1LE Join Date: Jul 2012
I found a thread on the ZL1 forums that lists factory offsets taken from the stamps on the wheels (with pics):
http://www.camaro5.com/forums/showth...factory+offset Offset: Front: 23mm, Rear: 43mm (stamped on the back side of the wheels) Hey all! I did some searching on the site and found the factory offsets. I have deleted the original text and replaced it with a link to the forum which tells the offsets and where to find them.
09-27-2013, 10:04 AM | #27 |
Drives: Camaro Justice Join Date: Jun 2007
There is are reasons your 1LE is equipped with the same size tire front and rear with wider rear than front rims.
The 5th Gen is nose heavy and the IRS hugs the road better than the virtual pivot front design. The combination creates massive amount of understeer, push when driven past 7/10ths. We addressed that way back in 2009 by fitting 305/30/19/XL Bridgestone RE-11s on Forgeline 10.5 by 19s all round. The square wheel and tire setup dramatically reduces understeer. For the 1LE the engineers on the Camaro TEAM selected 285/35/20. The rear tires are intended as drive and the fronts as steer. With the extra width in the rear removes some sidewall flex for better drive while the more narrow front allows for more sidewall flex to steer. The wheel widths, the application are well done. Changing tire sizes without corresponding changes to the wheels will do nothing but degrade the handling of your 1LE. Just so you know, the setup is so good that GM dumbed it down to induce more understeer. The ZL1 uses a 25mm front and 28mm rear sways. That is a pretty neutral setup, or as neutral as an OEM will sell, with staggered wheels and tires. The same bars on a 1LE with the semi square wheels and tires was too neutral so they dumbed it down by adding a larger front 27mm sway bar. The GYs are also dialed int for the heft of the 5th Gen. The sidewalls are stout. The should tread blocks harder than the super sticky center section. This combination provides durability when run hard on track along with great grip once they are hot. There are a lot of things you can do to improve the already great handling of the 1LE, but changing from the OEM spec tire and size has to be at the very bottom of the list unless you are fitting Pilot Sport Cups or some other D.O.T. legals slick. |
09-27-2013, 10:21 AM | #28 |
^ So keep the square setup and add bigger bar out back. Gotcha.
