04-14-2019, 03:18 PM | #1 |
Drives: Chevrolet Camaro 2SS Join Date: Mar 2019
MSD 2 Step Question
Hey everyone,
Had a couple questions about installing my MSD 2 Step on my M6 '17SS. The only video/thread I've seen on here advised me to tap into the yellow wire leading to the clutch position sensor. While at the same time running a toggle switch, to turn the car on. My question is, could I just tap into the cigarette lighter for the 12V and just use a toggle switch without tapping into the clutch position sensor? Has anyone had luck with this doing something similar or have they ran into the same problem I've been seeing where they have to use both the clutch and a toggle switch? Thank you, Nito |
04-14-2019, 03:48 PM | #2 |
Drives: SS-6-SPD Join Date: Jan 2017
I’m thinking about running MSD 2Step as well..
04-14-2019, 06:34 PM | #3 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
So are you trying to make it come on manually? As in not by using the clutch
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
10-15-2019, 09:21 AM | #4 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Anyone has tried this? I'll be using a momentary switch so it would be only working with the button pressed in and have the msd shut off as soon as I let go... Would tapping inthe the switched 12v in the cig lighter work ?
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
10-15-2019, 02:58 PM | #5 | |
This is how mines done, I just ran the wire out the old sound tube hole in the firewall and connected to the ground by the hinge for the hood
"Spitfire" 427ci
10-15-2019, 03:12 PM | #6 |
Who Needs to KNOW?
Is this for cars without launch control ?
ing for grip.
10-15-2019, 03:58 PM | #7 | |
@Blackmamba_1LE
Im actually going to drill a hole make it flush next to the shifter
10-15-2019, 03:59 PM | #8 |
@Blackmamba_1LE
All cars come with launch control... It just sucks from factory plus with the MSD I can change the rev point.
10-16-2019, 05:24 AM | #9 | |
I've done mine the ground wire set up for about a year now and love it. Push the button when you need it and it doesn't cause problems. When your at the track don't use it until the other guy is fully staged. If your on it too long you can get knock codes depending on your rpm. I floor it once the tree starts coming down and it's been pretty good for me. 1.54 60' is my best. Original clutch (probably 200+ passes) gforce aluminum DS, factory axles and rear end. 28x10 slicks 17" race stars.
"Spitfire" 427ci
10-16-2019, 07:17 AM | #10 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I gave up on this MSD2 Step once i ordered and found it it would work similiar to a killswitch, not very fond of that..
Anyone look into the lingenfelter sytem?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
10-17-2019, 02:05 PM | #11 | |
@Blackmamba_1LE
the Lingenfelter to me is overkill if you dont have a NOS system since it has the timing retard thingy. you are paying double the price for something you're ony going to be using half of it's features.
04-07-2020, 10:22 AM | #12 |
Drives: Turbo 6.2 Join Date: Feb 2019
I installed the msd 2 step using the brake pedal in an Auto.
https://www.camaro6.com/forums/showt...=554303&page=6
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
