08-10-2014, 11:31 PM | #1 |
windscreen rubbing my back seat
Has anyone fix this problem? [ATTACH]
[/ATTACH] |
08-11-2014, 04:32 AM | #2 |
"Katy"
Drives: 2014 2LT A6 'Vert Join Date: Feb 2014
Mine does that also. I put a styrofoam pipe wrap on it to see if that helps at all, because I can see the screen itself wearing at the leather.
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake Possible next mods: Throttle Body Exhaust Upstate C5 Member No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars.... |
08-11-2014, 05:48 AM | #3 |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
I was thinking styrofoam pipe too as a better solution. Spray paint it black?
Here is my back seat
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
08-11-2014, 07:24 AM | #4 |
Do you guys have the 10" woofer in the back seat? I do. I wonder if that has something to do with it?
08-11-2014, 07:41 AM | #5 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
Maybe try a peice of the softsided Velcro on the surface that makes contact with the seat?
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
08-11-2014, 09:06 AM | #6 |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
Mine does the same thing, but it's no big deal to me though.
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
08-11-2014, 09:31 AM | #7 |
"Katy"
It MAY have something to do with it, as posts from the other thread seem to point to only the 14s.. It starts at post #33
http://www.camaro5.com/forums/showth...=339127&page=2
08-11-2014, 09:37 AM | #8 | |
I have a 13 and have the same issue. Also have a sub. Post 33 put a tower but later said the towel only made it worse. I think the best option is styrofoam tube like others have done which I doubt will get rid of the mark but at least reduce it.
08-11-2014, 10:03 AM | #9 |
"Katy"
I just took a picture with it off, and I have been using the styrofoam pipe tube. It is still rubbing, but I'm not sure if it is better or worse. At least the plastic from the screen is not rubbing against it. By the way, I put the pipe tube all along the back of the screen, not just where it was rubbing on the seat so it seems to hit a little on the seats themselves. I may cut it back just so it does not do that.
08-11-2014, 03:32 PM | #10 | |
Can you snap a pic of the foam? Although the crease is there there it does look better than the crease that was there from the screen itself.
08-11-2014, 05:21 PM | #11 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
I would guess that putting anything between it will only increase the pressure against the seat...and the mark. Is there any way to modify it so it sits 3/8" forward?
08-11-2014, 08:28 PM | #12 |
Next day pictures. It left a rub mark. I tried to clean it. I'm not happy with this mark on my back seat. I paid over 300 dollars for this mark. |
08-11-2014, 10:07 PM | #13 |
Drives: '12 Hennessey Vert & '17 50th Vert Join Date: Jul 2012
I noticed that mine does the same thing. It only rubs when the screen (vertical part) is in the down position (laying flat) if you leave the screen up it looks like there is about a 1/16" to 1/8" gap between the rear of the (horizontal) windscreen and the seat back. So to solve the problem I just keep the screen up (or out).
Shoot straight, shoot often and share what you learn...My tactics instructor use to say "it doesn't matter what you carry, but you can never have enough ammo!!"
2012 Hennessey HPE600 Camaro Convertible Black, Inferno Orange Synergy stripes 2017 50th Anniversary Camaro SS Convertible |
08-11-2014, 10:21 PM | #14 | |
Mine has been up since I purchased it two months ago and have the indention :-(
