TireRack
Old 04-11-2015, 03:38 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Which Gears Are Best For FI?
Which gears are you running? Im running my stock 2SS gears and plan on throwing in a BTR stage 3 PD blower cam setup. Should i stick with the stock gears or change to like a 3.91?
Nighthawk89 is offline   Reply With Quote
Old 04-11-2015, 04:02 PM   #2
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
I posted in other thread and someone told me stay with stock 3.45's on a PD blower.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 04-11-2015, 04:17 PM   #3
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
I went with 3:45 but on a auto
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 04-11-2015, 04:46 PM   #4
Nighthawk89
Ive heard that too. But then i came across someone who was inlove with the 3.91's in his setup. Said it wss night and day. Wanted to see if anyone elze had the same experience.
Old 04-11-2015, 08:29 PM   #5
Jared91
Jared91's Avatar
Drives: 2011 Camaro SS/M6
I have 3.91's and I like it. I'll be installing a zl1 diff soon which will be 3.73
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
Jared91 is offline   Reply With Quote
Old 04-11-2015, 08:33 PM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Lsa conversion with the btr stage 3 pd cam, 4l80 trans and 3.73s. I love them!
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 04-11-2015, 09:54 PM   #7
Rumbumbees$ponsor
Rumbumbees$ponsor's Avatar
Drives: Autobot
I have same cam.. you be amazed how much it helps w 1le 3.91... In fact I was thinking I made a mistake with the cam choice. It's funny I called BTR and they said no you don't need gears.. technically you don't.. then called back with a question about some callies parts and mentioned I did the 3.91 gears with the cam and they said yall it really wakes it up and helps.
I would say its the best mod i have made yet!
Rumbumbees$ponsor is offline   Reply With Quote
Old 04-11-2015, 10:00 PM   #8
Rumbumbees$ponsor
Drives: Autobot
ya I was told the same.... but it just shows you they don't know sh!t.. It's the best mod I have done so far! I knocked my times down and on the street it pulls on other cars were i was being pulled on before!
