11-09-2016, 09:28 AM | #1 |
Drives: 16' 1SS M6 Join Date: Oct 2015
Plugwires with headers?
What plug wires are you guys with long tubes using? Bout to do my headers and exhaust and need some input. Thanks
Nightfall Grey 1SS 56F Black Bowties
11-09-2016, 09:36 AM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Accel has some with ceramic boots.....
11-09-2016, 10:00 AM | #3 |
Drives: 2016 Camaro SS Join Date: Oct 2016
When I installed ARH headers on my C7 last year I didn't see a need to change out the wires.
11-09-2016, 10:23 AM | #4 |
The engineer at Hooker said to get em so Imma get em :P Need to be 45s I found a set of MSDs on summit for the lt1 that look promising https://www.summitracing.com/parts/msd-33829/overview/
11-09-2016, 10:40 AM | #5 |
Drives: 2016 2SS Join Date: Nov 2015
I have SW headers and I they didn't mention anything about changing out the wires.
Is it common to have to change the spark plug wires? |
11-09-2016, 10:53 AM | #6 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
11-09-2016, 11:00 AM | #7 |
i have the oem ones and they work fine lol i was looking at the msd ones and was told no need
11-09-2016, 11:10 AM | #8 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
You don't need them, but the MSD ones are nice looking.
11-09-2016, 11:42 AM | #9 |
I mean the guy who designed them told me to get some I am a little wary to not at this point lol
11-09-2016, 11:53 AM | #10 |
You could try it and see. It's only for clearance the hookers could be shaped a bit different than some of the others.
If they fit fine and don't touch the header should be fine |
11-09-2016, 12:10 PM | #11 |
i have afe power headers and no issues here
11-09-2016, 01:33 PM | #12 |
"Lohla"
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
11-09-2016, 01:47 PM | #13 |
11-09-2016, 02:22 PM | #14 |
aFe Twisted Steel Tri-Y Headers Features:
•1-7/8” primary tubing which merge to 2-1/8” secondary tubes into a 3" collector •4-2-1 Tri-Y designed headers •3/8" thick, 304 stainless steel head flanges •Optimized tube lengths improve flow and performance •100% hand TIG-welded construction ensures optimal strength and durability •Incorporates a second bung for either a wide-band O₂ gauge or auxiliary instrumentation •Gasket set included X-Pipe: (Street Version): •Includes dual, hi-flow, metallic, 200 CPSI, stainless steel catalytic converters •V-band flanges with included V-band clamps for a secure leak-free seal •Incorporates an X-Pipe to balance and evenly distribute exhaust pulses traveling through the exhaust system, minimizing exhaust drone •This is a direct bolt on system when used with aFe Axle-Back P/N: 49-34068. Also fits stock exhaust system with minor cutting Testing: •In recent testing the “Street” version produced +24 horsepower and +27 lbs. x ft. of torque on our in house dyno. (Tested on a 2016 Chevrolet Camaro V8-6.2L w/aFe axle-back P/N: 49-34068) http://afepower.com/afe-power-48-341...-street-series
