Old 05-13-2019, 05:51 PM   #15
Chef-j
Drives: 2018 Camaro 1SS
Originally Posted by thescreensavers View Post
This,
Here are two Filters that now have the correct spec
Fram Ultra XG12060
WIX WL10290
Fram Ultra XG12060 are good? Ive been reading Fram Ultra are pretty good. Thinking about return my M1 filter and go back to WIX but i dont mind try new.
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 05-13-2019, 08:50 PM   #16
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Fram Ultras are one of the best on the shelf. I have a stash of Delcos I am running though they going with the Fram Ultra.
thescreensavers is offline   Reply With Quote
Old 05-14-2019, 08:16 AM   #17
PackAttack
PackAttack's Avatar
Drives: 2018 2SS Black MRC NPP
Fram Ultra XG12060? So is the XG10060 not the correct one?
PackAttack is offline   Reply With Quote
Old 05-14-2019, 08:37 AM   #18
thescreensavers
10060 is equivalent to PF48 which has 15psi bypass spec
12060 is equivalent to PF64 which has the 22psi bypass spec
Both LT1 and LT4 use the PF64 so you need to use the 22 PSI bypass spec filter(12060)
https://www.corvetteactioncenter.com...rint-1363.html
Old 05-14-2019, 08:51 AM   #19
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
You may be correct, but Fram has had so many QC problems over the the years, including oil filters that would pop off engines, that I won't ever trust one.
Emoto is offline   Reply With Quote
Old 05-14-2019, 12:37 PM   #20
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
every company has failures that make it through their QC. Otherwise this forum would be way less active since much of the posts are about something wrong with their camaro and if everyone stopped buying a product because 1 instance of it was bad, nobody would be able to drive any cars. Considering the number of filters fram sells, I'd imagine the % of failures is well in line with any other company you would be using. That and each line of filter isn't even made by the same "manufacturer" ...these big companies contract out actually making their products most of the time, which can change even one year to the next within the same product line. I've never heard bad things regarding QC about their ultra guard line.
if there was a pattern of poor quality, we'd know about it on the oil filter websites since they're like audiophiles for oil filters. Ultra Guard's are good and really shouldn't be considered as being made by the same company that makes the bottom priced fram filters.
Old 05-14-2019, 05:16 PM   #21
thescreensavers
Just buy Ultra its Frams best filter. The orange can which you are referring too is also used by OEMs (Nissan,Honda..etc) here in the US without problems.
I prefer better filtration and synthetic media in my filter so that's why I choose the Ultra.
The PF64 isn't bad either tho, just that the Fram filters finer particles. 99% at 20 micron vs 98% at at 25-30 Microns for the Delco.
Fram Ultra is about $9 and the PF64 is $6.18
At the end of the day ensure you are using the proper PSI spec and you will be fine with which ever filter OEM,Fram or Wix.
Old 05-16-2019, 07:23 AM   #22
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Be careful, there was an oil pump failure thread on here recently, where the dealer was denying warranty due to the filter not being OEM. I know its sounds stupid, but there it was.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 05-16-2019, 09:16 AM   #23
thescreensavers
Nothing wrong with OEM, just use OEM for less headaches.
An afternarket filter will cause more headaches if the dealer starts pointing at it but, that's just blowing smoke. I bet you could never get the dealer to put that in writing. Using the proper bypass spec will reduce some of that headache.
https://www.consumer.ftc.gov/article...ne-maintenance
Old 06-05-2019, 06:19 PM   #24
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Found the PDF regarding incorrect filters and warranty. Stated in the first sentence:
https://static.nhtsa.gov/odi/tsbs/20...78504-7690.pdf
breakskeet is offline   Reply With Quote
Old 06-05-2019, 07:51 PM   #25
thescreensavers
Important:Engine damage that is the result of an incorrect or improperly installed engine oil filter is not a warrantable claim.
The best way to avoid oil filter quality concerns is to purchase ACDelco® oil filters directly from GMCCA
So just use the correct filter
Fram and WIX both sell the correct filter with the correct bypass spec.
If you do not want to worry about it stick with OEM.
