06-11-2019, 08:29 PM | #15 |
he has a ZL1/1LE so its a stick. the more chop the worse the slow moving will be. youll be slipping the clutch or look like you cant drive a stick with too much duration. by the way big isnt always good. a friend of mine put a stage 3 cam in his 10 vette and I put a small custom cam in my 12 Camaro and I made more power on the same dyno.
06-12-2019, 11:27 AM | #16 |
Drives: SS 6 speed of course Join Date: Jan 2016
I have to be realistic, the number one reason for me looking at a loop-e cam is for sound, got WAY too much power already.
To the original poster: http://www.cammotion.com/camshafts/l...222-232-108-3/ sumting like this for a LT1 of course...
06-12-2019, 11:49 AM | #17 | |
Loop is more dependent on lobe center angle (LSA), a tighter lobe center eill really produce a far more drivable far stronger mid-range cam. Basically it is untrue that a loop-e cam will have a soggy response time. I'm sure a 110 LSA on a decent build will be a super fun responsive cam. I would agree the duration should be low 22X intake, low 23X exhaust for a street car.
