05-08-2019, 08:18 PM | #1 |
Drives: Chevy Camaro, Chevy Tahoe, VW Jetta Join Date: May 2019
LGX Cylinder Diagram
So several days searching the internet, AlldataDIY and this forum and I haven't found a clear indication of which cylinder is which on the LGX. Based on some posts for the LFX here and here, the newer V6s are the opposite of what Chevy engines used to be, as shown here. Is this accurate, and does this apply to the LGX as well? I have a misfire on cylinder 5, so I swapped what I thought was 3 and 5 (i.e. the two closest to the driver), but those may have not been the right ones.
05-09-2019, 01:46 AM | #2 |
Drives: 2017 Krypton Green LS 1LE Join Date: Dec 2017
Usually cylinder 1 is farthest from the transmission. So on the LGX your passenger side would be bank 1 with cylinders 1, 3, and 5(front to back) . Driver side would be bank 2 with cylinders 2, 4, and 6(again front to back).
Tags |
cylinder, firing, lgx, piston |
Thread Tools | |
