Old 05-14-2019, 09:26 AM   #15
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Originally Posted by eimarshall View Post
Have you run anything more than auto-X? I worry about the 305 on 10” combo for possible road course or track work. I really like the RS4s though.
I run the RS4s on a square set of 19x10.5" wheels for the track, but they run slightly skinnier than other 305s and TireRack says they are good for 10'12" wheels. I trust TireRack so I wouldn't be too stressed about running them on 10" wide fronts, I just went went with the setup that would allow me to rotate them.
IG: @NC_M1SS1LE
Old 05-15-2019, 12:12 AM   #16
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Gotcha. Thanks!
eimarshall is offline   Reply With Quote
Old 05-15-2019, 12:26 PM   #17
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I run 325/30R19's on a set of 19x10's and 19x11's off my old 5gen 1LE for track use and have no issue running 140+ down the straights and braking at the limit, 305's on a 10 would defiantly not be an issue.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 05-18-2019, 04:47 PM   #18
eimarshall
eimarshall's Avatar
Cool. Thanks for the info guys. Now i just gotta find some wheels. Anyone got any suggestions for stock SS 1le width in 19s? I have a set of apex for dd duty, having a hard time justifying $750 per wheel for forged stuff over Apex or some other roll forged brands.
Old 05-20-2019, 12:34 PM   #19
ICTsccaCamaro
ITCRNRS
Just have Forgestar make your a set in your spec, I believe mine were about $1600 a few years back
Old 05-22-2019, 02:25 PM   #20
Apex_Missing_Ape
Drives: 2018 2SS 1LE
Did you buy Apex's new Camaro-specific 19s? Factory 1LE offsets and widths, plus you don't need hub rings. That's what I'm putting new tires on for track duty. They are about 7-8lb lighter per wheel, which is pretty awesome.
https://www.camaro6.com/forums/showthread.php?t=551335
Apex_Missing_Ape is offline   Reply With Quote
Old 05-23-2019, 05:56 PM   #21
eimarshall
eimarshall's Avatar
Unfortunately no. I bought their bmw spec set in 2017. They are just 19x10 with all seasons for DD duty. Im not quite in the market yet for a full track set. Trying to burn through the stockers via autocross this summer. Then I’ll justify selling the oems and dropping to 19s.
I think i got forgeline and forgestar mixed up. The forgestars are right in line with Apex. Forgeline are not....
Old 05-29-2019, 08:46 PM   #22
Apex_Missing_Ape
Well, I actually did end up going with the R888Rs. They got really good reviews on various forums plus Walmart has them for cheap! 295/30/19s are only $281 and 305/30/19 was $345 (edit - $364). I could've gone with a square 295 setup for cheap but went ahead and went staggered. Provided my wheels come in by second week of June I'll be able to test them at Barber MSP.
