08-23-2019, 01:50 PM | #1 |
Drives: 1970 Boss 302 Join Date: May 2009
gasoline and LT1 option
Where I am we have 87,89, and 93 octane. What octane for daily use in the v-8 ?
Also, does anyone know if the cold air intake option is offered on the 2020 LT1 package ? Thanks. |
08-23-2019, 02:18 PM | #2 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
93 always. I can’t imagine GM wouldn’t option the CAI as it’s the same engine as the last 5 years of production.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
08-23-2019, 02:46 PM | #3 |
I only run 93 octane in my car. Lowest you can go is 91 due to the high compression ratio in the LT1 motor.
08-23-2019, 02:53 PM | #4 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
Performance Air Intake will be available for LT1, 1SS and 2SS but it is late availability. Not available for order yet for 2020 models.
08-23-2019, 03:00 PM | #5 |
Drives: 2016 SW 2SS M6 Join Date: Jun 2018
GM recommends 91+, but the car can run on regular.
I run 91/93 in mine, but you can bet that most of the Camaro SS's that you see in rental car fleets run on regular most of the time |
08-23-2019, 04:04 PM | #6 |
What speed limit?
Drives: 2017 SS 1LE Join Date: Jul 2019
Absolutely 93 only. I would drive to another gas station before I put anything less than 91 in my car.
08-23-2019, 04:14 PM | #7 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
91 minimum. It actually likes more than 91/93.
08-23-2019, 04:23 PM | #8 |
What speed limit?
As a side note I also stick with top tier gasoline brands only. For me these are places like QT, Exxon, Shell, Costco etc. I avoid Racetrac, 7-11 Gas, Wal-Mart/Sam's (Murphy USA) etc.
08-23-2019, 04:26 PM | #9 |
Runs perf fine on 87, never saw a diff from 91.
08-23-2019, 05:11 PM | #10 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
It is factory tuned on 93 which is not available everywhere. 91 is good but 87 would be bad. Another reason why this is not my DD.
Sent from my iPhone using Tapatalk |
08-23-2019, 05:33 PM | #11 |
08-23-2019, 06:58 PM | #12 |
Drives: 2016 2SS (M6) Join Date: Jun 2018
93 plus a splash of E85
If you had a tool that could read ECU parameters, you would see quite a bit of timing retard and knock if you used 87. It most CERTAINLY makes a difference, you may just not be able to notice it. |
08-23-2019, 11:29 PM | #13 |
Dumb Ass Deluxe
08-24-2019, 12:16 AM | #14 | |
Sorry but do you really think that you know where this gas is actually coming from. Don’t be silly! Sent from my iPhone using Tapatalk |
