04-06-2020, 03:57 PM | #15 |
Drives: cheby Camaro Join Date: Aug 2019
Depends on what you like but I like 0 to .3 neg camber, slightly toed in depending on the tire width. The more negative camber (top of the tire canted in) the more heavy and planted the steering will feel. Too much camber and you will feel every little defect in road surface and may feel harder to steer. I notice on most cars if you don't have a little neg camber the tires will wear to the outside. Toe depends a lot on the width of the frt tires. If you are using the stock 245's in the frt they are very forgiving to tracking so you can go with 0. I use just slightly 1/32 in BUT thats what you see while measuing it. Driving down the road is completely different. I play with the adjustments and see how the car responds till I like what I feel. Slightly toed in causes the tires to load the suspension and hold it tight. Toed out does just the opposite and causes the car to feel loose. Depends what you like, Zero toe is for CAFE fuel mileage numbers and feels ok. Keep something else in mind, if you are a big 200 lb dood put some ballast in the drivers side before they align it. It does and will effect the alignment.
04-17-2020, 07:49 AM | #16 | |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
04-17-2020, 04:02 PM | #17 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
04-21-2020, 01:39 PM | #18 | |
Drives: 2015 Camaro Join Date: Aug 2018
I got so fed up with this on past vehicles that I purchased my own DIY alignment tools for this car. It's not that hard once you learn the basics. The best thing is, I can dial in my own settings for better handling or just do a "tight spec" OEM alignment. From my experience, you really can't depend on a big box chain with minimum wage workers to do something like that. |
04-21-2020, 09:05 PM | #19 | |
04-22-2020, 10:22 AM | #20 | |
